02-22-2016, 03:32 PM | #1 |
Rep 896
M3 Exhaust System Terminology
Let me start by saying, I've tried to search, but I find the searching on this forum to be difficult.
I was hoping someone could clarify all the different parts/terminology of the M's exhaust system. For example, what is an X-Pipe? Test Pipe? Mid Pipe? When someone just says exhaust, does that mean from the cats and back? If someone could list all the consecutive components/parts of the exhaust from the engine to the tips after the muffler, that would be great. Thanks in advance
Previously:
2010 E92 335 (6MT) 2011 E92 M3 ZCP (6MT) |
02-22-2016, 03:39 PM | #2 |
Rep 1,678
Drives: 2011 MCB E92 M3
It goes like this - Headers / X-pipe (primary and secondary cats and resonators) or midpipe / Exhaust.
Test pipes only replace the Primary Cats, which reside on the X-pipe or midpipe Exhaust usually refers to the portion just after the X-pipe on our cars.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
02-22-2016, 03:46 PM | #3 |
Rep 6,696
Drives: F30 340i
i'll leave this photo here because it helped out a lot when i first started learning about exhaust systems. i won't answer all your questions, but here are the simple ones:
we have an x-pipe. see how they are shaped? test pipes replace the primary cats on our cars. the most power/sound will come from "deleting" your primary cats. test pipes are popular versus getting a full x-pipe because they are much cheaper and subjectively yield the same results. i would assume mid pipe refers to xpipe. most people use the term xpipe. based on context it might refer to a specific part of the xpipe? when someone says "exhaust" it could mean anything. usually they just mean the muffler. there are the tips, muffler, and xpipe. |
02-22-2016, 03:47 PM | #4 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Pic of the exhaust system:
X-pipe is the center section (the "X" is under the black cross-brace). Toward the front of the car next to the black transmission cover are the primary cats. This is where a "test pipe" would go. Replacement muffler portion would be an "axle-back", everything aft of the X-pipe.. |
02-22-2016, 06:32 PM | #5 |
Rep 4,488
I've always thought the M3's stock headers (aka exhaust manifold, the part that attaches to the engine) are a work of art. For comparison, here is a C6 Z06's stock headers:
And the M3's: In case you weren't aware, the reason for the much more complex design on the M3 is so that all cylinders have equal-length exhaust tubes. Further reading here if you're interested: http://www.vikingspeedshop.com/equal...ust-manifolds/
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 02-22-2016 at 06:44 PM.. |
03-05-2016, 11:21 AM | #6 |
Rep 16
Just one more reason why I love the S65 she looks and sounds good. What else can one say.
But you definitely need to mod or change the exhaust. She will come alive then. |
