03-16-2016, 09:08 PM | #3 |
Rep 3,148
Looks like the OEM open diff to me, non LSD
03-21-2016, 08:06 PM | #7 |
Rep 2,402
No, you cannot "vector torque" with rear brakes (or anything else) and an open diff. Torque split across an open diff is ALWAYS 50/50, period. Always.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
03-21-2016, 11:19 PM | #8 |
Rep 1,850
Hahahaha. What in the hell are you talking about? That's how an open diff works lol, it sends the power to the side of least resistance.
03-28-2016, 02:22 AM | #9 | |
Rep 101
It's counter intuitive, but that's the physics behind it. |
03-28-2016, 02:55 AM | #10 | |
Rep 1,850
50:50 torque split means each wheel gets 50% of torque. An open diff has a 0:100 torque split as soon as traction is lost. It's not counterintuitive in the slightest. And yes, this is a REGULAR OPEN DIFF--the car uses the rear brakes to slow whichever wheel loses traction. This is hardly theoretical territory, everyone knows the car has an open diff and software to simulate a LSD. Last edited by The Wind Breezes; 03-28-2016 at 03:03 AM.. |
04-14-2016, 11:04 PM | #11 | |
Rep 101
Do you know how much power (torque) your engine makes when not under load? Bugger all. When one wheel is on a slippery surface the engine will have hardly any load against it, so the engine might only make 30Nm. With an open diff, 15Nm will go to the wheel with no traction, and 15Nm will go to the wheel with traction. If you open the throttle more, the engine might rev up, but it won't actually produce more torque. so you will only always get the same amount of torque to the wheel with traction. I am not disputing what the 135i has (open diff, brakes to simulate LSD). I am saying that ALL open diff have a permanent 50:50 torque split. I hope this helps you understand: https://www.youtube.com/watch?v=_HOa0aRZYpw |
