04-08-2016, 09:27 AM | #1 |
Rep 709
Condensation in headlight housings
Anybody else getting condensation in their headlight housings? I just noticed it this morning and was wondering if it's a broader issue...
Thanks |
04-08-2016, 09:46 AM | #3 |
Rep 1,547
I had condensation and water issues with my RR tail lamp assembly, but nothing on the headlights. I would say if it doesn't clear within a day or two, have your dealer replace.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
04-08-2016, 09:54 AM | #4 |
Rep 709
Response from my CA: "This time of year with any rain and humidity, there is some small amount of condensation. The headlights get so hot, they should burn off the condensation. There are small vent holes for the housing because they do get hot. They would overheat if there wasn't. If there is always excessive condensation, it should be covered by warranty."
04-08-2016, 02:26 PM | #6 |
Rep 748
Not sure how it is normal. Go to dealer, which, as i can assume, is located in the same area as your car, and ask them to show how many cars on a lot have the same wet from inside headlight. I bet, there will be none. Ask them "why is it only your car has it?"
Ones drove a Reliant Robin. )))
04-09-2016, 04:45 AM | #7 |
Rep 289
had this on all my cars for the very first few weeks.
guess its the residue vappur from all the manufacturing process ocasionaloy I get this on rapid weather condition change in combination with car wash = rapid temperature and humidity change, but its away in few hours seems like your case, only rain instrad of car wash and warm sunny evening I suppose with car parked on the sun? simply => air condensation. the light is not vacuumed if persist, faulty light Iam afraid |
04-09-2016, 12:36 PM | #8 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I always though condensation warranted replacement. At least it was on every other car I've owned.
04-09-2016, 08:00 PM | #9 |
Rep 748
^^Exactly! +100
04-09-2016, 09:51 PM | #10 |
Rep 2,995
the headlights are not sealed. they have little vents to allow air to expand and contract.
the air vents out as the light heats up. then when you park, the light cools off and air is drawn in. you may just have excess humidity inside, for whatever reason. on a dry day, pop the hood, and remove the covers on the back of the headlights, and blow a hair dryer in there for a bit, to get rid of the moist air. |
04-10-2016, 12:51 AM | #11 |
Well versed in the care and feeding of BMWs
261
Rep 733
+1^^^
No condensation here, yet. Will apply above technique if I find it.
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
04-10-2016, 01:22 PM | #12 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Here's the thing. The vents are for the electronics to let out heat. It is so designed so air can pass through, but in no way should water get in there. They are not there to let water evaporate. There is a barrier between the front and rear parts of the headlight. Water should not be able to get in. Any dealer that says otherwise is ignorant. If there is condensation in the housing, it's from a leaky seal. Leaky seal is a defect therefore warrants a replacement headlight assembly. If condensation was normal you'd see it on all cars, but you don't.
04-10-2016, 05:03 PM | #13 | |
Rep 2,995
and if you look at the pic, its freezing rain on the outside, so the moisture/humidity inside the light is condensing on the cold lense. |
04-10-2016, 09:28 PM | #14 |
Self-Deprecating Narcissist
7266
Rep 6,561
water collection and pooling is warrantied. condensation is not.
12-03-2018, 05:12 PM | #15 |
///M
196
Rep 272
Drives: 2015 F15 X5 50i M Sport
Reviving this thread...
Is this seriously normal? Just noticed the driver's side headlight has condensation when I left work this afternoon. Passenger side is fine. It rained over the weekend and was dry and in the 50s today.
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
12-04-2018, 04:10 PM | #17 |
Rep 865
There is a Technical Service Bullitin on this; B630516 appears to be the right number, but I can't find the full text. Dealer should be able to show you the TSB which should state at what stage the condensation is abnormal.
I knew I had seen this somewhere:
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 Last edited by MN2///M; 12-04-2018 at 04:30 PM.. |
BimmerTy195.50 |
12-07-2018, 02:18 PM | #18 |
Rep 62
I got the same issue on my passenger side. There is a seal on the top to access the bulb assembly that was cracked and I glued it back together and it helped slightly. To dry it out I ususally leave it open after driving it so the heat helps the moisture evaporate up and out. Still get some condensation its really cold or rainy but not the big droplets like before.
BimmerTy195.50 |
