04-20-2016, 05:05 AM | #1 |
Rep 20
FS: Oem modified e92 M3 exhaust
I have just upgraded my M3 e92 exhaust to Dave Dee's M3 full stainless system. Very meaty and beastie sounding.
Anyway, I have a modified rear section where the perforated pipes in the rear section had been cut out and re-welded with solid pipes to provide a louder and deeper than standard note. See this video for an example: If you're interested, happy to sell rear section for $600. Sid |
04-20-2016, 05:22 PM | #2 |
Rep 309
I used to run the 2 pipe mod and it sounded great. This is a good buy for anyone that wants to keep their stock muffler mint for resale.
What do you think of the upgrade to Daves system? |
04-21-2016, 09:36 PM | #6 | |
Rep 1,074
I've had Evolve tunes on my e46 and E92. Ran fine both times and customer service was great. |
04-21-2016, 10:11 PM | #7 |
Rep 309
They must have trouble with the e92 tunes. I had a non burble tune supplied and still had problems. They ended up blaming my exhaust which is just test pipes and high flow secondaries. I'll go BPM when I SC. I really couldn't recommend evolve.
04-22-2016, 03:59 AM | #8 | |
Rep 1,464
Drives: BMW X5M Comp
What issues are you having with the tune? Did you check the plugs and coil packs? A suspect plug will cause problems, when fitting a SC plugs should be changed as a part of the install unless they have few Ks. |
