04-22-2016, 09:49 AM | #1 |
Rep 348
Calling all strange noise experts - What is this sound? (not a bearing thread)
All,
Let me start by saying that I've heard this noise on other cars of varying makes and models, so it's not e9x M3 specific. However, it has gotten progressively worse over the last 6 months and it doesn't sound very "M" so it needs to go away. At least this isn't another "bearing thread." The sound is a chatter. My car is a 2011.5 with a DCT. What I know: 1. It occurs after the car has been warm for a 20 minutes or so. 2. It only happens when the car is in gear, under load, and somewhere between 1500-3000 rpm. 3. As stated above, in neutral, this sound does not occur. 4. I first noticed the sound when switching into reverse or climbing inclines into parking structures. Now I can hear the sound under load on the freeway. 5. I can feel lateral vibrations in the steering wheel that I believe correlate with the sound. This is new, and troubling. My best guesses: 1. Driveshaft play. 2. Loose belt. 3. Busted engine mount. 4. Flex plate chatter. I finally capture the sound on video. Happy hunting! *fingers crossed for something inexpensive and insignificant* |
04-22-2016, 09:58 AM | #3 | |
Rep 656
04-22-2016, 10:09 AM | #6 | |
Rep 348
Longer video added above. |
04-22-2016, 10:20 AM | #7 | |
Rep 1,611
It is something that definately has play and engine mounts on slight acceleration do not chatter like that. Give me some time to think about it and maybe get a short clip from the inside, drivers side compartment? Thanx. |
04-22-2016, 10:32 AM | #8 | |
Rep 348
It's possible that the lateral vibrations aren't related to the sound and are something that I've incorrectly related. It's possible, but I'm pretty tuned in. Keep in mind - I've heard this sound come from other cars (E350s, Taurus, MX3s alike). Same sound, same tone, same circumstance (accelerating from a stop). There's got to be a commonality. |
04-22-2016, 11:21 AM | #9 |
Rep 1,611
Ok, when I can rely on your statement, that this chatter sound only occurs, when in gear and under load, I can definately only point out 2 relevant factors, wich would be:
engine or driveline related. Now the thing is...where does that sound come's from? Front, middle or rear of the car? As for now: It almost sounds as it could be something vibrating that isn't rotating, like an heat shield somewhere underneath the car? You know? You can do alot of supporting actions, like take a picture from underneath the car. That way, we might be in the position to help you, as we would see if something would look off in a way. Did you had any codes recently? |
04-22-2016, 11:41 AM | #10 | |
Rep 348
As for where the sound is coming from, it sound like it's coming from the bottom middle of the engine bay. From inside the cabin, it sounds like it's coming from somewhere between the engine and the space between the driver and passenger footwell. As for codes, everything is clean and clear. Unfortunately, I won't be able to get pictures of the underbelly of the car. I guess I can take it as a good sign that we didn't diagnosed the problem instantaneously. Good that it's not a major, known issue; bad that it could be anything rattling loose. Could this be a simple blown engine mount? That would make sense to me given the symptoms (and the knowledge that my engine mount(s) hasn't been changed yet). |
04-22-2016, 12:11 PM | #12 |
Rep 656
Put on swing arm lift and drive it in gear with the wheels off the ground, and have someone else isolate the area of noise from underneath... There are just too many possible things it could be; not to mention that the steering vibration may not be related...
You can try on jackstands, but I would not recommend it if avoidable... I am thinking of several things- -driveshaft joint -clutch chatter -motor mounts -trans mounts -exhaust shield -exhaust |
04-22-2016, 12:18 PM | #14 | |
Rep 348
I like your idea re: putting the car in drive while suspended. It's worth a try. However, I'm concerned the sound only occurs when the engine is torquing something as the motor is perfect while in neutral. This is shaping up to mean a trip to Malek at MRF. |
04-22-2016, 01:28 PM | #15 |
Supreme Czar
309
Rep 779
04-22-2016, 01:33 PM | #16 | |
Rep 348
Driveshaft play was my first thought as it makes the most sense and the sound comes from where I imagine the driveshaft was chatter under load. But driveshaft chatter is fairly common and the noise my car is making is pretty distinct. I expected someone would have called it right away if it was the driveshaft. |
04-22-2016, 01:58 PM | #17 | |
Rep 1,611
My car was developing bad vibrations around 180km/h. Funny cooncidence I replaced mine today and the vibration I was getting are now completely gone |
04-22-2016, 02:09 PM | #18 | |
Rep 656
04-22-2016, 02:14 PM | #20 | |
Rep 656
04-22-2016, 04:22 PM | #22 |
Rep 348
