04-23-2016, 11:55 AM | #1 |
Supreme Allied Commander
3887
Rep 54,530
Drives: F80 M3
Performance Friction has replaced the legendary 01 compound with the 11. For the E9x
Performance Friction has replaced the legendary 01 compound with the 11. For the E9x M3 and E82 1M, 01 is being phased out for the new 11 compound. 08 will continue to be produced.
11 Compound 11 Compound is a new generation sprint and medium distance friction —the ultimate in control, with superior disc conditioning. 11 compounds were developed from the 01 compound with improved bite, modulation, and release characteristics. It is ultra smooth and developed to reduce wheel locking at the end of a stop. Brake with confidence—brake with ultimate control and modulation. For many applications, 11 will replace the venerable 01 compound. 11’s wear is par with PFC’s legendary 01 compound. Virtually zero taper wear when raced in a properly designed race caliper. Recommended Applications: Ideal use for medium-low grip venues where control and modulation is at a premium Racing venues where ABS systems are used Can be used in a large spectrum of temperature ranges. For more information: http://www.hpashop.com/Performance-F...C01-e82-1M.htm |
