BMW M3 Forum (E90 E92)
      03-12-2008, 07:02 PM   #1
rai
rai's Avatar
Drives: M3 coupe with DCT
how does an ipod sound on a HI-FI system?
I am not an audiophile but consider myself able to hear some sound depth or quality. I'm curious what you are able to hear with ipod or mp3 compression with a true hi-fi system. I mean does it sound worse than a source material recording considering you have so much more definition and the compression may make it sound like a 3rd rate copy.
As I say, I am no expert, but on other cars (not hi-fi system) it seems like a ipod is tinny or small in certain range of notes.
If getting the premium system would it be better to skip ipod if it's going to be bad sounding? Save the $$ and just stick with source CD recordings?
What's the feeling about ipod quality?
      03-13-2008, 12:10 PM   #2
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
iPod is worth it for sure. this is what i recommend. take your iPod to a dealer and tell him you want to hear it in the car. they'll be more than happy to let you do that
      03-13-2008, 12:39 PM   #3
M3aHOLIC84
M3aHOLIC84's Avatar
13
Drives: 2002 Laguna Seca Blue M3
a buddy of mine has a camry and i can say it sucks ass...it is so dimmed out and nasty sometimes...also depends on how well the original recording of the song is...and you certainly cant forget what kind of speakers your listening it on...that would make a big difference
      03-13-2008, 01:57 PM   #4
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
on my 335 it was awesome. i didnt want to give too much positive feedback, maybe his ear is more sensitive than mine. but it was great on 335 with logic7
      04-19-2008, 09:02 PM   #5
GregW / Oregon
Commander-In-Chief
2122
Digital music formats
For those conversant with bit rates and encoding. I currently am using an iPhone and my CDs are ripped to it at stadard AAC 128kb. Is there a noticeable difference going to 256kb, or should I skip the whole thing and use a lossless format with a hard drive?
Thanks.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      04-19-2008, 09:13 PM   #6
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
Thanks.
Go 320kps variable bit rate (VBR) if you have the space in your iPod... for me it is the best compromise between song size and sound quality.
      04-19-2008, 09:16 PM   #7
GregW / Oregon
Commander-In-Chief
2122
I don't see that as an option in iTunes?
      04-19-2008, 09:44 PM   #8
fmquadri
fmquadri's Avatar
11
Drives: 08 E92 M3
Using decent headphones and even on moderate sound systems you can tell the difference between 128 and 256 and 320. Good recordings show even more quality and depth with better bitrate conversions.
I would recommend 256 as the minimum - if you can, 320 VBR. Not sure if Itunes will do that itself. You may need to get a separate MP3 ripper (LAME MP3 codec) and create your own - then import into itunes. Its worth the extra effort, IMHO.
MP3's playing in the M3 that were ripped at 128 sound metallic and a little tinny.
Higher bitrate ones sound great.
      04-19-2008, 10:00 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Thanks--it's obvious that higher is better, but want to find the best quality/size compromise. I know this will vary with different listeners.
      04-20-2008, 01:00 AM   #10
gorun
gorun's Avatar
46
Drives: W166 ML63 PP
Ipod sounds bad as it does internal conversion and obviously has cheap DACs. I can confirm that USB sounds much better both in my home and car! If you can go USB you wont regret it, just make sure you encode at a high bitrate -256 or 320.
      04-20-2008, 01:12 AM   #11
Davinhci
Davinhci's Avatar
Drives: 08 M3 E92 & 08 E70 X5 4.8
2008 M3  [0.00]
sorry how do you encode the bitrate?
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights |
      04-20-2008, 07:16 AM   #12
Technic
Technic's Avatar
2295
Go Edit > Preferences > Advanced > Importing > Setting > Custom:
Stereo Bit Rate = 320 kps
Use Variable Bit Rate Encoding (VBR) = check
Quality: Highest (MP3 only setting)
For MP3 you can set also subsonic filter at 10Hz; not available for AAC.
m3post
