05-21-2016, 03:05 PM | #1 |
Rep 4,341
anyone running 265/35/18 front and 295/30/18 rear on stock 1M?
I just saw the Apex group buy and I'm thinking of EC-7 wheels 18x9.5 ET 22 FRONT and 18x10.5 ET 27 rear. I would run 265/35-18 and 295/30-18
Has anyone run this on stock 1M? Rubbing or other issues. I would like to autocross this setup with everything else stock? |
05-21-2016, 03:48 PM | #2 |
Rep 313
I run the the 265 up front and 285 rear on the apex 18s without any rubbing and I'm stock. I think I could go to 295 on the rear because there seems to be more room. I use the Hankook RS3 tires. I'm not sure what my ET are but if you need me to ck I can look tomorrow when I get back home. I got my set up from Harold at HP so he might be able to help you out.
2024 X3 M40i
2011 1M Coupe VO (Sold) 2015 MB GLK 250 Blutec Deez (Sold) 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
05-21-2016, 04:44 PM | #3 | |
Rep 4,341
05-21-2016, 10:50 PM | #4 |
Rep 509
I have R888 just now running 265 fronts and 295 rear with KW v3's with a pretty aggressive drop with no issues. I'm sure I could run 305's in the rear, still tons of room.
ilikebmxbikes1518.00 |
05-22-2016, 03:20 PM | #5 |
Rep 313
I got the same...22 front and 27 rear. I think I could go wider in the rear, but the front I think would rub on anything wider than 265.
2024 X3 M40i
05-22-2016, 04:21 PM | #6 | |
Rep 4,341
07-14-2016, 01:38 AM | #7 |
Rep 31
I am running 19s BBS
Front 265/30/19 Rear 295/30/19 Front will scrab and rear just light touch |
09-07-2016, 03:06 PM | #9 |
Rep 175
18x9.5 +22 ARC8 with 265/35R18 Michelin PSS - will rub on full lock, more during reverse than going forward. Stock (un-notched) liner. -2.8 deg camber up front
09-19-2016, 09:48 AM | #10 |
Rep 231
Pics? I am running 275/35 front and 295/35 rear and rub when I am at full lock in reverse. Not a big deal.
09-20-2016, 09:56 PM | #11 |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
295 in the rear will vary in fitment. Round shoulder tires will work fine where as squire shoulder will rub, but typically 295 is okay.
M3 Adjuster7909.00 |
10-31-2016, 01:50 AM | #12 |
FOUO
415
Rep 873
Running APEX PS-7 ET22 all around with Yoko AD08R 265/35/19 and 295/30/19.
I get a little rub when I'm on full lock, and rears slightly rub when hitting bumps. But that's probably because I need to adjust my camber/tire sidewalls being thick |
11-20-2016, 04:25 PM | #14 |
Rep 263
11-20-2016, 05:05 PM | #15 |
Rep 309
The 265/35/19 didn't work out. The tire was too close to the coil collar, and the tire rubbed the inner fender well, no matter the ride height. 3mm spacers were required just so I could drive home. If they made 265/30, I am positive it would have worked. I had to put 255/35/19 on. No spacer.
Keep in mind, different tires are different widths, even if they are the same size. These 255 RE-71-R are wider than the 255 Pilot Sports that came off. |
12-25-2016, 12:08 PM | #16 | |
Rep 11,785
02-23-2017, 04:01 PM | #17 |
Rep 6
Will 265/35/ R19 front and 295/30 R19 back Toyo R888's fit stock wheels on lowered (20mm) stock suspension?
As far as i know, the R888's have quite round edges. |
02-24-2017, 05:33 PM | #18 |
Rep 2,819
Drives: e82 1M, f87 M2cs
I doubt it, I used 255/35/R19 last year on the front with the revised fender liners and there isn't much room to spare.
If you still have the original liners, there is no way. I had rubbing issues with 245/35/R19 on the original liners when I switched from the stock Michelins to slightly chunkier Bridgestone RE-11's a few years ago. That prompted my dealer to replace the liners, which was covered by warranty since my replacement tires were correctly sized.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
02-25-2017, 07:32 AM | #19 |
Rep 2,898
I've run those tire sizes with Michelin Pilot Super Sports for the last couple of year in the One Lap of America and get only minor rubbing in the rear with the car fully laden during the transits when going over certain low frequency bumps.
Neil |
05-09-2017, 05:09 AM | #20 | |
Rep 260
BSM 1M owned from new.
05-16-2017, 06:28 AM | #22 |
1mGator
144
Rep 567
Nacho,
Been running 265/30/19 and 295/30/19 now for 2 years on lowered H&R. Front left liner rub on full lock in parking lots and occasional rub on right rear with passengers at speed with heavy bumps. You will appreciate the extra "grip" of the rears especially if you are tuned my friend! Now contemplating spacers or adjustable to fix rear gap left to right as right rear seems to sit lower than left for some reason. Go for it! |
