06-03-2016, 11:39 AM | #1 |
Rep 433
Manual transmission fluid DIY guide?
Tried searching, didn't find anything
Is there a DIY guide to changing the 6MT transmission fluid on the F8X? I'd like to do it myself since the maintenance doesn't cover it. Thanks in advance
______________________________
?05 E46 M3 ZCP 6MT ?06 C55 AMG '97 911S 6MT |
06-03-2016, 11:37 PM | #3 |
Rep 3,945
Drives: 2015 M4 MG/SO
Read my posts here (4,6,8,10) http://f80.bimmerpost.com/forums/sho....php?t=1200522
using Google to search BP is helpful: http://bfy.tw/66El |
06-04-2016, 05:47 AM | #4 | |
Rep 433
The "let me google that for you" link is a little annoying...
06-04-2016, 06:54 AM | #5 | |
Rep 3,945
The only picture is there, it's too two hex plugs and the torque doc is also attached. I understand it's not a step by step detailed real life pics. One word of caution, if those two docs are not enough, I nicely and humbly recommend that you don't do the DIY. Last edited by aboulfad; 06-04-2016 at 07:05 AM.. |
06-06-2016, 09:27 AM | #7 |
Rep 476
06-06-2016, 12:16 PM | #8 | |
Rep 445
06-06-2016, 02:58 PM | #9 | |
Rep 3,945
The S55 6MT is the ZF GS6-45BZ K designation, but always check the part using realoem or your VIN in Rheingold. |
06-21-2016, 10:28 PM | #10 | ||
Rep 1,001
Drives: 2016 F82 M4
2007 e92 335i 6MT | Cobb AP Stage 1+ | ETS FMIC | AFE Dual Cone Intake (Sold)
ED 8/18 - PCD 10/19 | 2016 F82 M4 6MT | Alpine White | CF Roof | CF Trim | Black Extended Leather | Executive Package | Lighting Package | Adaptive M Suspension | 19" 437M Black Wheels |
06-22-2016, 06:30 AM | #11 | |
Rep 3,945
On my previous BMW, I modded the transmission fluid bottle with a 1/4" flexible pipe and used gravity as a "fluid transfer pump" |
06-22-2016, 07:57 AM | #12 |
Rep 2,770
I had luck getting the dealer to change it at my 1200 mile service. If you can give them a good reason to do it under warranty they normally will oblige. I commented that the shifting felt notchy and would occasionally stick while going into gear. The SA had the fluid changed with no further issue. It doesn't hurt to ask and since we have M cars it seems the dealers are more inclined to make us happy.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
10-14-2020, 09:35 AM | #13 |
Rep 4
Has anyone actually done this job themselves? I just did my car at 41k and was wondering if I was filling it properly. I could only get 1.4L in not sure if that is right. Would appreciate any feedback.
10-14-2020, 05:24 PM | #14 |
Rep 1,001
Drives: 2016 F82 M4
If it started to spill out of the fill hole then you should be good.
10-18-2020, 11:51 AM | #15 | |
Rep 408
Simple Basic F80 6 spd manual fluid flush. https://f80.bimmerpost.com/forums/sh....php?t=1635315 |
10-25-2020, 07:45 PM | #16 | ||
Rep 4
