      06-15-2016, 11:29 AM   #1
EldRick
Drives: 1M VO - #161 US
Left low beam malfunction error message
After installing LED angel eyes some moisture got into one headlight assembly after a wash.
I got it dried out, but now I'm getting no high or low beam headlights on that side, and an error message "Left low beam malfunction".
Curiously, my code reader finds no codes from this.
Anyone got an idea what this might be?
      06-15-2016, 12:19 PM   #2
Mark 1M
Mark 1M's Avatar
United Kingdom
349
Drives: M2
There is a control unit under the light take it out and see if it is dirty
if you take the wheel off you can remove the wheelarch to get at it
      06-16-2016, 08:11 AM   #3
LukeM3
Drives: X3
What type of code reader are you using?
      06-16-2016, 12:27 PM   #4
EldRick
A Cobb tuner - apparently an engine-only code reader. I took it to a guy with a full-diagnostic setup, and he found codes from the body computer. After using his computer to exercise the headlights, they "healed", and now work OK.
Weird.
I also found out, as part of that, that the cornering lights are more interesting than I had realized:
- the center halogen beams are used for cornering, one at a time - the one in the direction you are turning comes on while the normal beams also turn in that direction,
- the cornering light switch position is actually full-automatic - the lights only come on when outside light is dim or dark, not in daylight.
Both were a surprise to me.
Tags
error, headlight, low beam
1addicts
