06-26-2016, 07:23 PM | #1 |
Rep 1,239
Pic request. Spacer related
Anyone got a pic of a stock height car with wheel spacers that push it out flush?
A job is nothing but work.
06-27-2016, 12:22 AM | #2 |
Rep 391
06-27-2016, 07:17 AM | #5 |
BMW CCA member and you should be too!
217
Rep 478
What type of wheel studs to you have?
06-27-2016, 11:25 AM | #6 |
///M
237
Rep 703
Holy shit I found my exterior twin. We even have the tire rub marks!
Follow me on IG: dre.pt
06-27-2016, 12:17 PM | #7 | |
Rep 1,236
Apex studs. I don't recommend them. They rusted inside in the hex head in less than 1 month. I told them about it and it took them two weeks of back and forth to tell me its normal and they won't do anything about it. Maybe their bullet nose studs are better.
Do you know why those tire marks happen? I plan on lowering so I'm guessing the rubbing will get worse. I think my alignment is wack so I was hopping getting that done will fix it. |
06-27-2016, 12:30 PM | #8 |
///M
237
Rep 703
It's rubbing against the wheel housing. (black plastic above tire.) That's the issue for me. I have 265/35/19" 295/35/19" stock ZCP height. Take out your wheel and inspect the wheel housing for rub marks. You will find where it hits. My main issue with it is that my rear tire when hitting a bump hits the part where the rear bumper and side panel wheel arch connect. Kind of pointy but not for me anymore because my tires shaved it off.
06-27-2016, 05:46 PM | #9 | |
Rep 1,236
06-28-2016, 11:17 AM | #12 |
Supreme Czar
309
Rep 779
06-28-2016, 11:21 AM | #13 |
Rep 1,239
I was considering that as well. snap a pic if you can. thx
06-28-2016, 12:04 PM | #14 |
Supreme Czar
309
Rep 779
06-28-2016, 12:23 PM | #15 | |
Rep 371
