06-27-2016, 01:16 PM | #1 |
Rep 1,300
Scuffed iDrive Screen
Hey guys,
I bought my car used, and the previous owner probably used the ledge in front of the screen as storage because the bottom 1/4" or so on my idrive screen got some scuffs on it. It appears only the anti-glare coating is scratched and it's only noticeable when the sun/glare hits the screen at a certain angle. Doesn't really bother me too much, but does anyone know if there is a way to fix that other than replacing the screen itself? |
06-27-2016, 01:23 PM | #2 | |
Rep 392
http://www.bestplasticcleaner.com/ |
06-27-2016, 01:41 PM | #3 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Polishing the screen will only remove more of the AR coating, which is quite fragile. Companies like NuShield sell replacement self-adhesive film coatings custom cut for the screen. The film provides a matte anti-reflective surface but I have not seen one that matches the purplish reflection of the stock coating.
You can remove the screen easily with two screws and a cable disconnect. You can then polish off the remaining factory AR coating with a mild polish (like Novus). It comes off very easily; then you have an even surface for the replacement film. |
06-27-2016, 01:47 PM | #4 | |
Rep 3,740
Drives: 2018 M2
06-27-2016, 01:54 PM | #5 |
Rep 1,168
Couple of comments re NuShield:
- it's slightly smaller than the screen size. Which may be useful as it's really hard to polish out the coating along the edges due to metal frame. But if you're a perfectionist and manage clean the screen completely, the visible edges of the protector will annoy you. - it's super reflective. Makes the screen appears brighter, with more saturated colors, though. Given the price ($20 or do), next time I'd just use one of ipad-like screen protectors that are dime a dozen, and just cut it to perfect size. |
06-27-2016, 10:30 PM | #6 |
Rep 1,300
Thanks for all inputs.
Do you guys think I can use plastic polish to remove the anti-glare coating? I looked up the novus stuff and it seems like that is just plastic polish. I like the idea of iPad-like screen protector. I've had success with the invisible shield film. |
06-27-2016, 11:17 PM | #7 | |
Rep 6,732
The NuShield should have come with peel off tabs and a thicker release carrier to make it sturdier for application purposes. |
06-28-2016, 12:50 PM | #8 | |
Woof!
352
Rep 1,323
