New 2009 2010 BMW Z4 - ZPOST
      06-29-2016, 08:58 PM   #1
saintvilk
Drives: BMW 2009 z4 E89
ER chargepipe install help. not fitting into oem rubber hose
Hello all,
I need some help, i have recently purchased a ER chargepipe and it seems like while installing the chargepipe onto the the lower intercooler hose with the rubber hose at the end, it doesnt fit well.
it seems like its about 1inch shorter and at slight different angle than the oem diverter pipe.
Does anybody have any advice on how to get this new ER chargepipe with the OEM intercooler rUbber hose and clamp together? any advice would be great
thank you
      06-30-2016, 07:56 PM   #2
Lambobimmer
Drives: 2022 X3 M40i, 2018 TTRS
http://e89.zpost.com/forums/showthread.php?t=1063842
I went through the same problem when I had my Z4. To save you some time, the ER CP will only work with their FMIC. I returned mine and bought a Stett CP and it fit perfectly.
      07-01-2016, 11:43 PM   #3
saintvilk
Yeah i tried to fit it again with no luck with the ER chargepipe and the stock intercooler and all, i think i will mtake you advice in going with stett chargepipe, do you have any pictures and/or videos with the car using it and install?
      07-02-2016, 09:14 AM   #4
Lambobimmer
I am not sure if I do, but I promise you that the Stett CP fits perfect. I spent way too many hours with ER that their CP did not fit except with their FMIC and I finally gave up and returned it. I ended up buying a used Stett FMIC and a new CP and never looked back. The Stett FMIC is built specifically for the E89 to take advantage of the extra room that the Z4 has available.
      07-19-2016, 07:57 AM   #5
saintvilk
Thanks for the help the stett chargepipe fit wonderfully with the tial BOV . thanks again for the help and advice
zpost
