08-04-2016, 10:36 AM | #1 |
Joint Chiefs of Staff
4923
Rep 115,999
N54Tuning.com - Fuel-It Port Injection System now Available!!!
Fuel-It E-Series Port Injection System
ORDER LINK http://www.n54tuning.com/fuel-it-e-s...on-system.html PRODUCT DESCRIPTION Are you running more E85 or making more power on pump gas than your HPFP (High Pressure Fuel Pump) can support? We have developed a port injection kit for your N54 or N55 that will provide you with the additional fueling capacity that you need to be able to run up to 100% E85 on stock or upgraded turbos. What is port injection? Port injection is a kit that is installed between your intake manifold and the cylinder head to provide you with more fueling than your stock system is capable of. It's a relatively easy system to install and does not require any permanent modification to your car. We offer our port injection kits in five different packages to meet your needs: Basic kit inludes: (This kit does NOT include any fuel lines) Fuel-It! custom black anodized spacer for the intake manifold Fuel-It! custom black anodized fuel rail Black anodized aluminum and stainless steel hardware Dual fuel supply port for those that are running inlets in the stock location (email us for info) Optional return port for those that will be running an upgraded fuel pressure regulator Six of the following: Flow matched Bosch injectors (52#) Extended length steel studs (and a bolt) for mounting your new spacer BMW OEM gaskets Bronze kit inludes: Basic port injection kit Basic fuel line connection kit Two custom Fuel-It! fittings to maintain your stock fuel line connections at the HPFP and the feed line as it enters the engine bay -6an (3/8") upgraded fuel lines High flow "Y" adapter 90 degree elbow for the fuel rail connection Silver kit inludes: Basic port injection kit Basic fuel line connection kit An upgraded fuel line that completely replaces the stock fuel line Gold kit inludes: Basic port injection kit Basic fuel line connection kit An upgraded fuel line that completely replaces the stock fuel line Integrated ethanol sensor (additional ethanol analyzer must be installed to read ethanol content) Platinum kit inludes: Basic port injection kit Basic fuel line connection kit An upgraded fuel line that completely replaces the stock fuel line Integrated ethanol sensor Ethanol Analyzer of your choice JB4 integration compatible 0-5volt Bluetooth (Iphone or Android app must be purchased to use this feature) If you are using an Apple product the app can be found by clicking here If you are using an Andriod product the app can be found by clicking here *These kits are available for off-road use only *All port injection kits are built to order so please allow 2 business days for shipping. *Ethanol Sensors don't actually read the ethanol content, the readings are based on the absence of gasoline, so if your fuel is contaminated, your ethanol readings may be artificially elevated. |
08-07-2016, 09:59 PM | #2 |
4923
Rep 115,999
08-14-2016, 08:37 AM | #3 |
4923
Rep 115,999
08-20-2016, 09:15 AM | #4 |
4923
Rep 115,999
08-26-2016, 12:53 PM | #5 |
4923
Rep 115,999
09-02-2016, 05:21 PM | #6 |
4923
Rep 115,999
09-07-2016, 01:10 PM | #7 |
4923
Rep 115,999
09-09-2016, 03:20 PM | #8 |
4923
Rep 115,999
09-14-2016, 07:01 AM | #9 |
4923
Rep 115,999
09-18-2016, 03:10 PM | #10 |
4923
Rep 115,999
09-21-2016, 09:38 PM | #11 |
4923
Rep 115,999
09-26-2016, 05:40 PM | #12 |
4923
Rep 115,999
09-29-2016, 07:33 AM | #13 |
4923
Rep 115,999
10-04-2016, 08:10 PM | #14 |
4923
Rep 115,999
10-10-2016, 08:49 AM | #15 |
4923
Rep 115,999
10-15-2016, 07:07 AM | #16 |
4923
Rep 115,999
10-21-2016, 06:35 AM | #17 |
4923
Rep 115,999
10-24-2016, 12:55 PM | #18 |
4923
Rep 115,999
10-30-2016, 04:08 PM | #19 |
4923
Rep 115,999
11-05-2016, 04:32 PM | #20 |
4923
Rep 115,999
11-11-2016, 04:14 PM | #21 |
4923
Rep 115,999
11-16-2016, 06:53 AM | #22 |
4923
Rep 115,999
