08-26-2016, 11:20 AM | #2 |
Rep 3,740
Drives: 2018 M2
Cons are if its oiled improperly or not ideally it will be more restrictive. Pros if it's oiled and cleaned properly it will be less restrictive than paper filters and filter better at least it's how they're advertised I'm sure this thread will turn into a fiery debate honestly all you get with oiled filters and more responsibility and better intake sound
R3dliner936.50 |
08-26-2016, 01:09 PM | #3 |
Rep 108
I have wondered the same thing. There is a lot of information out there, but nothing that really answers the question "dry versus oiled". A lot of people would just say go with OEM. It filters the best, and if changed regularly, allows more than enough airflow to the engine. The oiled filters seem to be less restrictive to both airflow and dirt, which would make some sense. I chose to go with the AFE Pro Dry S because of this.
Here is a link to some air filter tests: http://www.billswebspace.com/AirFilterTest.htm Now it is time to sit back and wait...
2011 E90 Silverstone II / Fox Red/Black ZCP Manufacture Date 10/28/2011
08-26-2016, 01:33 PM | #5 | |
Rep 876
I went with AFE Pro Dry S too. I believe they actually publish a filter efficiency rating. Most of the oiled do not. |
MyUnicorn61.50 |
08-26-2016, 05:49 PM | #6 |
Rep 2,445
Drives: 2022 M3 6MT
I've ran K&N since owning the car. No issues. Maybe a bit more induction noise.
No wrong answer here.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
08-26-2016, 07:56 PM | #7 |
Enginerd
118
Rep 542
Not sure if it still applies but in the past some oiled filters were known to gunk up MAF's. This is in general and not specific to S65. I went with AFE dry as well.
2008 E92 AW 6MT /// 120k orig rod bearings
08-26-2016, 08:01 PM | #8 |
Rep 876
08-26-2016, 08:58 PM | #9 |
Enginerd
118
Rep 542
I stand corrected and you are correct, there is just the inlet air temp sensor. So does DME get air intake reading from air pressure sensor off of idle control system?
08-26-2016, 09:17 PM | #10 | |
Rep 876
My understanding is that it has a MAP sensor that works from air pressure so some oil wouldn't really impact it. |
08-26-2016, 09:26 PM | #12 |
Rep 230
They say you CAN/SHOULD go for 50K. But I clean mine every 10K. After cleaning and oiling, I let the filter sit for 2 to 3 days so I know I've let it dry enough that even if I've over-saturated it, it's dried up for those days. I do this for both my E46 and E93.
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
R3dliner936.50 |
