08-28-2016, 06:57 PM | #1 |
Rep 561
Turbo exhaust v-band clamp
I am pretty unimpressed with the v-band clamp from BMW, in particular the thin metal plate that is spot welded. Is there a higher quality replacement? Do they fail? (hard to imagine they don't). I realize there is not much room under there.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport. |
08-29-2016, 03:12 PM | #2 |
Rep 887
Check SK-Speed. They sell them...
http://skspeed.com
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
fmorelli161.50 |
08-30-2016, 07:57 PM | #3 |
Rep 561
Thanks ... oddly I've not found any reference to people changes these v bands out on the N54. I'm surprised ... clearance is a bit of a challenge.
Filippo
08-31-2016, 10:16 AM | #4 |
Rep 1,473
Not sure why this is needed because I have never seen one break. It is easiest to install your DP's if you move the steering rack and you use an air ratchet to tighten the bolts. I think that I can do it in a little more than an hour.
09-26-2016, 11:40 AM | #5 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
So you moved the steering rack and it helped? Good to know.
On my 2011 Z4 It didn't seem like it was going to help any so I left it alone. Pretty tricky to get in there though for sure. The worst was getting the Vband back on. Off wasn't too much of a problem. |
