09-12-2016, 01:41 PM | #1 |
Rep 381
tires for bbs f1. 19 inches
Hey I just pulled he trigger on a set of BBS FI (F - 19x9.5 ET28/R - 19x10.5 ET23). Im also a little lowered on ohlins R/T and was wondering if you recommend buying a set of MPSS on
255/35/19 and 275/35/19 . (I don’t have the updated fender liners.) Or what other tire do you recommend, the car is a weekend car used for highway runs. I don’t want to run 30 profile tires as roads here in Mexico are filled with pot holes. regards diego |
09-13-2016, 10:04 PM | #2 |
Rep 2,819
Drives: e82 1M, f87 M2cs
On the original fender liners, you would likely rub slightly at full lock at stock ride height. I am not sure if the lower stance helps or not. Are you using the stock upper mounts or have you added negative camber?
