11-01-2016, 03:50 AM | #1 |
Rep 289
4.0Diesel loss of power/no kick down-FIXED
So yesterday I went for a car wash and on the way back after getting on freeway I tried to hit it hard but nothing....... the car did not downshift to get RPMs over 3k, kick down did not work. Was very lazy.
Looking at the sport gauges where it shows torque and HP all went to half max. No errors, nothing. Sport mode made no difference either.... the power was not there. Could not revv it over 3k when in gear. Was able to do so in neutral though. so turned the car off for 30 mins, went back in and all was fine. gave a her a hard ride on the highway and the power was back, all ok. any ideas??? perhaps a water in some of the sensors? car thought it was cold so was in some easy modus?? anyone?? Last edited by pragueX5; 11-07-2016 at 01:00 PM.. |
11-06-2016, 03:49 AM | #4 |
Rep 289
so the car is in for diagnostic.
do you guys know if the proper diagnostic can tell a lot? meaning if they go to detail especially when the instrument cluster actually says nothing at all? |
11-07-2016, 10:43 AM | #5 |
Rep 1,547
Odd issue for sure, especially since it's sporadic. I had a similar issue with mine, turned out to be a wastegate issue and the turbo was replaced under warranty. Very much became a safety issue, where the vehicle would literally fall on its face and loose all power. Keep us posted on the dealer's findings.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
11-07-2016, 11:42 AM | #7 |
Rep 5,066
Pretty cool that the power is reduced to protect the engine from whatever the problem maybe. This is the way it was designed.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
11-08-2016, 05:59 AM | #10 |
Rep 289
not so sure about this as if this was the case (protection mode) it should come with a warning light on the idrive, which it did not at all........
11-09-2016, 10:54 AM | #11 |
Rep 1,547
Wow, cha ching on the parts. Glad you got it sorted (under warranty).
