11-26-2016, 02:52 PM | #1 |
Rep 638
Does Aux Heating Also Pre-Heat The Engine Block - With FLIR Pictures
Hi All
So it's getting colder here in the UK (relatively) and I'm starting to use the aux heating in my X5 regularly. I must say I'm pretty impressed, good amounts of heat pumping into the cabin after only a few minutes running! However, I thought that the aux heater would also pre-heat the block / oil / coolant to make cold starting less rough on the engine and to give a nice quick warm up. But I'm starting to be less convinced that this is happening as time goes by. Anyway I fished out my FLIR camera today and ran the aux heat for about 30 minutes before taking a look round the car. The cabin was lovely and hot, as was my drive under the aux heating exhaust! - About half way along the passenger side of the car. But while I could see heat in the pipes running from the heater pack to the matrix behind the bulkhead I couldn't really see any sign of the block gaining any heat. I can't be certain because it's a pretty big lump and is shrouded with all sorts of bits and bobs blocking my view. Does anybody know for sure if aux heating does start to heat the engine, or is it only the cabin? |
11-27-2016, 09:21 AM | #4 |
Rep 638
I think you might be right. Perhaps I've picked up on the block heating from looking at Webasto units which may well offer this as they are aftermarket and designed for more extream situations...
