11-28-2016, 07:33 PM | #1 |
Rep 226
Drives: E93, E38, E53
Thermostat cel?
So recently I got a cel for having a faulty cel. Anyone ever seen this before? Not sure how the dme even knows how a mechanical component like a thermostat is bad. I'll grab the actual code tomorrow. Just wanted to see if anyones ever had a similar code before ordering parts.
Car has 93k on it. Never overheats. Only mods are a macht schnell cat delete and a bren tuning tune to disable the cel for no cats. |
11-28-2016, 07:54 PM | #2 |
Rep 58
The computer actually watches how fast the engine warms up. If it takes too long, it assumes the thermostat is stuck open. Mine did this about 70K. My daughters Jetta did the same thing. There is a great DIY.
11-29-2016, 08:47 AM | #4 |
Rep 226
Good to know. So just a new tstat and I'm good. I'll get some new orings too just to be safe.
11-29-2016, 10:06 AM | #6 |
Rep 226
Any particular reason why? Nothing wrong with it and it doesn't look very difficult to change if I needed to later on.
11-29-2016, 10:10 AM | #7 | |
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
They should be changed together.
11-29-2016, 10:17 AM | #8 | ||
Enginerd
118
Rep 542
OP, at 93k you should just replace both. Water pump is a wearable item, mine went out around 90k and I did pump, Tstat and coolant flush at that time.
2008 E92 AW 6MT /// 120k orig rod bearings
11-29-2016, 01:26 PM | #9 |
Rep 2,526
For those of you replacing your water pumps, are you using GEBA, OEM, or OEM refurbished units?
And if you are going to replace all of these then you might as well replace the temperature sensor as well - it's the cheapest part of the three. |
11-30-2016, 12:14 AM | #11 |
Rep 1,326
i replaced both the thermostat and temp sensor to be on the safe side. might as well while you have everything apart.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
