12-25-2016, 01:54 AM | #1 |
Rep 145
Scratched ZCP Wheels
Hey all,
My left rear ZCP wheel has some scratches underneath the clear coat. When I run my hand over the scratches I can't feel them so I assume these can't be waxed or anything. Anyone know what I can do to fix this? I bought the car like this. My car is still under warranty and I'm wondering if this is a defect that the dealer can take care of? Any thoughts are appreciated! |
12-25-2016, 02:36 AM | #2 |
Rep 1,408
If the dealer will warranty it, you have nothing to worry about, you will get a new wheel. Go in and ask them.
But if the dealer cannot, best bet would be to buy one of those scratch removing polish products from any car parts store and clean it with a microfiber towel. Worked on one of my older cars, worth a try. |
12-25-2016, 02:46 AM | #3 |
Rep 7,131
Yep get the dealer to sort it. You may want to double check that the new rim colour match the current ones. Tricky to match should they be re painted.
12-25-2016, 03:15 AM | #4 |
Rep 323
If its under warranty and the damage wasn't caused by you I would try the dealer, I had problems with the clear coat on my 335i rims and they replace the entire set under warranty.
12-25-2016, 04:48 AM | #5 |
Rep 3,450
Dealer warranty is always worth a shot..
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
12-25-2016, 12:28 PM | #6 |
Rep 822
sorry to say...those are not scratches and can't be "buffed out". its the clear "checking" or "cracking". Needs to be striped and re painted.
Hopefully BMW will help you out on this. |
12-25-2016, 12:38 PM | #7 | |
Rep 436
12-25-2016, 01:19 PM | #9 |
Rep 145
Reply
12-25-2016, 01:48 PM | #10 |
Rep 1,792
yeah, that wheel has been refinished before, and the emblem was put back upside down.
You need Son Tran for this: https://www.yelp.com/biz/onsite-wheels-garden-grove |
eyanez123044.00 |
12-30-2016, 02:16 PM | #11 |
Rep 4,341
Yes, it's upside down. Probably wheel was refinished. for some reason the guys that refinish them, always put them upside down. Sometimes the dealer refinishes them before sale and you don;t know it. My 1M has the same wheels and one day when cleaning them with soapy water and a soft towel the silver paint started to come off. These were refinished in my humble opinion. The cracking and the upside M decal are big signs.
eyanez123044.00 |
12-30-2016, 02:18 PM | #12 |
Rep 4,341
Also, when I wash my car, I drive it around the block once to clear the rust off the rotors before storing it. These rotors will corrode quickly if you put them away wet and leave them there. You will end up with pulsating pedal.
Just a thought! Best wishes. |
eyanez123044.00 |
12-30-2016, 04:20 PM | #13 |
Rep 1,933
Drives: 2013 E92 M3
It looks a lot like lacquer checking!
01-01-2017, 03:29 AM | #14 | |
Rep 145
As for the wheels, took it to my local BMW dealer, they contacted BMW NA and they said I need to take it to where I purchased it, so I'll be doing that next week and see what the outcome is. I'll keep everyone posted on what happens in case anyone ever runs into this issue. |
01-01-2017, 12:05 PM | #15 | |
Rep 4,341
On the wheels, I have owned three sets of these ZCPs since 2011. One brand new set that came on my car in 2011, one set I bought from a 2012 that changed wheels and used them for autocross tires and my current set on 2011 1M that was from BMW of Toronto. I have never seen that cracking and my wheels are 5 years old. I noticed that one wheel on the car that came from BMW of Toronto had a black mark on the edge of the lip that I thought was just rubber rubbing on the lip from a pothole. So I took some warm water with car wash and gently started to rub it and the it was black underneath and the paint started to come off. Then I noticed that the M decal was upside down like yours! : ) All of the other three wheels had the M decal correctly so something was done where that decal was re-attached. I hope they take care of you. Best wishes and happy new year! |
eyanez123044.00 |
01-01-2017, 12:56 PM | #16 | |
Rep 145
Thanks man! Happy new years to you as well! |
