01-02-2017, 11:20 AM | #1 |
Rep 40
Anyone install aftermarket amp in EPS/Ind system?
I couldn't find much in a search about this topic.
Has anyone re-coded EPS to hifi and amplified all stock speakers with say a multi chanel jl amp? I'm curious about - how many channels of balanced outputs are you left with after recode - would I require new passive x-overs for the front stage or would I be needing to separately amplify tweets mids and woofers? As that would be 6 channels there, how do you set up rear stage. Would the stock hi fi outputs provide speaker outs to power the rear fill or would I need another multi ch amp to drive those? - Does this recoding provide a pure flat signal free of eq and silly speed-adjusted volume eq? - I read somewhere that the speaker outputs just require a speaker wire/rca cable and I would be good to go direct to amp(s). Are any harnesses required? - Will there be any improvement in sound quality? I'd likely add a processor into the chain as I'd like to also add another music source (streaming) I read somewhere this is a preferred approach but don't really see much by way of install or info on the approach. |
