01-03-2017, 11:54 AM | #1 |
Rep 57
Competition Pack EDC Shocks on 08 M3
If I pick up a set of Comp Pack EDC shocks can I plug them directly into my 08 without any coding? I know the springs are different but is there any benefits to adding the Comp Pack shocks to an 08 that doesn't have the same software as the later cars?
I currently have a set of BC Coilovers that came on my car. I'm looking for a more stock feel and all of the EDC components are still intact, I just need the shocks. Thanks! |
01-04-2017, 08:48 AM | #3 | |
118
Rep 691
01-04-2017, 08:49 AM | #4 | |
Rep 633
Lutfy |
01-04-2017, 12:13 PM | #5 |
Rep 57
My main issue isn't really the ride. Somewhere in the front they're making a popping noise. Kinda sounds like coil bind but I adjusted the spring pressure and made sure all the bolts are tight. It's not all the time. I usually hear it at low speeds. |
01-04-2017, 09:20 PM | #7 |
Rep 143
I retro fitted the ZCP pack struts and went with Dinan stage III suspension. I did code the car for the ZCP struts though. It's been about 20K miles and I love it!
2009 E90 ///M3 SG Fox Red 6MT Slicktop, AA X-pipe w/straight pipes w/Eisenmann Sport, Dinan intake, AA Pulley, ZCP strut retro w/Dinan Stage III susp, BPM Stage II tune, Rear Fog LCI switch, BMW Edition Front & Side Grill/Gill, Thrust Arm Monoball, Solid Subframe Bushes, Black 19x9.5/10.5 APEX PS-7s, Vibra-Technics engine mounts, Auto Solutions shifter 20% throw, WPC treated Rod Bearings & AiB v4-Now, Not Wife approved!!
01-04-2017, 11:48 PM | #8 |
Rep 988
If it's pre lci you may need to do more than just zcp coding... I think you may need the full zcp wire harness.
Otoh if you want to retain full edc functionality just get a set of Bilstein B16 coilovers... that utilize Bilstein shocks that plug into the edc system. I think I just saw a post with someone selling a used set. |
