01-12-2017, 06:11 PM | #1 |
Rep 1,300
How BMW tested and built our engine.
Found this video today, not sure if it's old but It's pretty neat to watch.
http://jalopnik.com/this-is-how-bmw-...-m3-1791112839 ...and no one there caught the rod bearing issue.. |
01-12-2017, 08:38 PM | #2 |
Rep 3,140
Drives: 2014 M5 6MT
The rod bearing issue doesn't constitute a 100% failure rate across all S65's buit. If you built 100 engines (let alone thousands) using the same methods you would have a certain percentage of failures. Its very possible the engineers never noticed an issue because there never found one on the engines they tested. Food for thought.
2014 M5 6MT
01-13-2017, 04:41 AM | #3 | |
Rep 1,318
01-13-2017, 07:39 AM | #4 |
4-6-8
234
Rep 990
It failed on the S85 and the S65. I bet they knew but the cost/benefit didn't make sense for them to fix. Warranty failures would be covered but after that they don't care.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
///M Power-Belgium64252.50 |
01-13-2017, 10:06 AM | #5 | |
Rep 1,178
It looks like this engine testroom cannot test at different ambient temperatures. They ran the engine red hot in the video but that means the oil reached warm temperatures first to protect the engine. What they didn't do is freeze that room overnight then cold start, run normaly for couple minutes then floor it. Also the pitch from the video does not sound like redline. |
01-14-2017, 09:28 AM | #9 | |
Rep 24,867
The S85 is produced from 2005=>2010 ,and BMW saw bearing failures.. The S65 is produced from 2007=>2013 ,and BMW saw bearing failures.. ///M BMW made not once but twice the same mistake ! And they replaced worldwide S65-S85 engines from 2005 => 2017. And in the years ahead ..... About your freeze temps in the testroom... Do you know that 70% of the S65-S85 worldwide bearing failures happened in countries where it never freezes ? This are facts and not speculation . One thing was/is speculation , it's BMWs financial speculation.
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
01-14-2017, 05:02 PM | #10 |
Save the manuals!
6033
Rep 6,753
*4 times The S54 and S62 also suffered from bearing failures, as did some of the S50B32... Hell I know personally know of one S63 X5M with bearing failure just a few months into ownership from new.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
01-14-2017, 06:14 PM | #11 | |
Rep 436
01-14-2017, 06:29 PM | #12 | |
Rep 24,867
2- I stored in the last 4 years the worldwide bearing failures in my database 3- Private information 4- And from here => http://www.m3post.com/forums/showthread.php?t=786615
01-14-2017, 07:28 PM | #13 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
///M Power-Belgium64252.50 ///Motown61.00 |
01-14-2017, 08:59 PM | #15 | |
Rep 1,300
http://thegarage.jalopnik.com/bmw-en...hit-1784684330 Last edited by MaximusB; 01-14-2017 at 09:05 PM.. |
01-15-2017, 11:53 AM | #16 | ||
Rep 1,178
Those are industry standards and will be closer to corporate reality than outsiders speculating that bmw ignored the issue. What is certain is the issue was known by bmw when they started design on the F8x gen. The evolution to more stringent emissions regulation was convenient to justify the shift away from NA to FI. But even without that , they were probably coerced to get away from semi-exotic engine issues that didn't fit their commercial high volume goals by their financial team. Last edited by Rajmun340; 01-15-2017 at 12:15 PM.. |
01-15-2017, 12:48 PM | #18 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
///M Power-Belgium64252.50 99332.00 |
01-15-2017, 03:27 PM | #19 |
Rep 24,867
You received a PM ..
01-16-2017, 06:01 PM | #20 |
Rep 837
Can you pls pm me too that info, thx
01-16-2017, 06:07 PM | #21 |
Track Whore
542
Rep 1,640
01-21-2017, 11:38 AM | #22 |
Rep 24,867
