New 2009 2010 BMW Z4 - ZPOST
      01-18-2017, 06:00 PM   #1
sjobusen
Drives: BMW Z4 35i
Adding inlets and outlet after tune
I am planning to add inlets and outlet on my n54.
I have today a 93oct cobb pro-tune on my car.
What will happened after I mount the inlets and outlet?
Will the engine work ok without re-tune it? Will my car be drivable?
      01-18-2017, 11:35 PM   #2
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
It will be fine. No better without a retune but no worse.
      01-20-2017, 11:23 AM   #3
jts1981
jts1981's Avatar
213
Drives: n54
which outlets are you going with? I was going to pull the trigger but Chris from Vargas said I would need an adapter to fit with my Wagner Evo I fmic...
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
      01-23-2017, 08:51 AM   #4
sjobusen
Drives: BMW Z4 35i
I am planning to get the MMP inlet and outlet...
      01-23-2017, 01:43 PM   #5
NoQuarter
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
I have installed the MMP inlets and outlet:
- The stock rear inlet removes without cutting it out. Stays all in one piece and can be used again.
- No need to lower the engine, drop subframe etc
- The rear silicone inlet is difficult to attach securely. If it is not perfect, it WILL come off at a later date when you are messing with it up top when removing/install air box/filters.
- Remove the downpipes and the rear turbo actuator and mounting bracket to secure the rear silicone inlet.
- My front inlet seems a bit too long and is not a perfect fit where it attaches to the air box. I'm not sure if I could route it better or not.
      01-23-2017, 01:45 PM   #6
NoQuarter
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
Unless someone SWEARS they have a kit they made for the E89, expect to need an adapter or 2 regardless. If E89 is listed in the long list of models just because it has the same engine, assume you will need something different to attach the inlet and outlet.
      01-24-2017, 02:12 PM   #7
jts1981
jts1981's Avatar
213
Drives: n54
BQ is using the VTT inlets with ER intercooler, no adapter between outlet to intercooler needed. My woes come from my Wagner EVO I which is oem set up.
I'm thinking more and more to modify an oem unit. I've been reading that the silicone outlets have been failing over time.
      01-25-2017, 08:47 PM   #8
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
I did the MMP with ER. Outlet side is a tight fit and takes some finagling. I was not able to install the heat shield back in place (though I'm going to take another run at it) and I cut one of the studs off the frame rail for the heat shield as the tube was being poked by it.
That said I have 1,500 miles on my setup without issue. It's a tight and challenging fit, but it is big and definitely free flowing. You want power ... ;-)
Also Mauricio at MMP provides great support.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      01-26-2017, 06:30 PM   #9
Eracer76
Eracer76's Avatar
Drives: 2009 E89 Z4 35i
I made my own custom passenger side inlets, and I bought and installed the MMP outlets last summer... I haven't had any issues with either of them
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
zpost
