01-18-2017, 09:05 PM | #1 |
Rep 138
Finally: Rod bearing replacement
For those of you who have similar mileage and blackston data...this is what my bearings looked like. Car saw about 15+ trackdays in 2016.
01-19-2017, 11:57 AM | #4 |
Rep 3,140
Drives: 2014 M5 6MT
Now lets not all run out and schedule a bearing service at the same time! Seeing how there are reported bearing failures at 13k miles or less, this cannot be used as a basis for the recommended replacement mileage/oil report data. Its all a gamble. Safe bet is to change them preventatively, or shortly after a used purchase.
2014 M5 6MT
01-19-2017, 04:35 PM | #7 |
Rep 10,672
Its definitely not a placebo for the guys with copper showing through their bearings. Maybe the next set of bearings will wear prematurely as well, but changing the bearings is a lot cheaper than replacing the motor.
///M Power-Belgium64252.50 |
01-20-2017, 12:45 PM | #9 |
Rep 138
Knowing how they look now and knowing that I have 4 track weekends coming up in the first quarter of year...I'm glad these are being replaced. I just figured it's easy to cough up $1200 instead of thousands and thousands more when they fail.
01-20-2017, 03:08 PM | #10 |
Rep 1,171
$1200?!?! That's a steal!!
01-20-2017, 03:11 PM | #11 |
Rep 5,508
Exactly, you're playing roulette with the M3. If the rod bearings go, you're left with nothing. Better to be preventative than sorry.
Auto Detailing Enthusiast!
01-20-2017, 03:56 PM | #12 |
Rep 804
Drives: Some fun stuff
How many have rod bearings that have actually let go? Most forums where there is evidence of engines with catastrophic failures have some type of thread (such as the 2.0t engine failures in the Caddy ATS forums) where those people with bad luck can post up their experiences. I haven't seen one of those around here. In fact, in the 1.5 yrs I've been here, I might have read a single new thread about engine failure due to bearing wear. I'm all for getting on the "the S65 is a poorly engineered masterpiece due to crappy bearings" bandwagon, but I haven't seen the evidence nor have I seen any real science/engineering describing the cause of the bearing wear.
I'm happy to stand corrected and learn if I'm missing something. |
01-21-2017, 08:30 AM | #14 | |
Rep 727
http://www.m3post.com/forums/showthread.php?t=1344612 http://www.m3post.com/forums/showthread.php?t=1337022 I would suggest checking out the Auto Couture Rod Bearing Thread. It'll show you every set of bearings taken out of an S65 had significant wear, independent of mileage. Higher mileage cars seem to have more wear. Low mileage cars are also affected. If this wasn't an issue then independent shops wouldn't be offering these services, companies wouldn't be manufacturing alternative bearings, and cars wouldn't be blowing engines. It's not something that is blown out of proportion either. Otherwise perfect M3s are being taken out from this. I had been looking at M3s for a long time. Finally pulled the trigger on a low mileage car (33k) Bearings were pulled...you guessed it, worn. A not so scientific explanation... the reason this happens is due to the clearance of the RBs around the crank. It makes contact, wears the lead, copper, and other metals off the RB, and that gets into the engine. Boom. Choosing a replacement bearing, whether coated or with a bigger clearance, will avoid this. (which option is best is for another thread) |
01-21-2017, 11:01 AM | #15 |
Rep 1,933
Drives: 2013 E92 M3
Many of the engine failures were broken valve springs!
01-21-2017, 12:14 PM | #16 | ||
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
shimmy232356.00 |
01-21-2017, 12:20 PM | #17 |
Rep 984
What year is your M3? Looking at the copper content I'm guessing an early S65? What replacement bearings did you go with? I'm considering BE bearings but Ive yet to see any longtime reviews.
2004E46M36MTCBCinn 'Clubsport'
01-21-2017, 12:22 PM | #18 |
Rep 984
What year is your M3? Looking at the copper content I'm guessing an early S65? What replacement bearings did you go with? I'm considering BE bearings but Ive yet to see any longterm reviews.
01-21-2017, 12:28 PM | #19 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
