BMW M3 Forum (E90 E92)
      01-23-2017, 08:18 PM   #1
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
Wheel And Tire question
Hey guys,
I just have a question regarding fitment on my E90 M3. I have work vsxx wheels. The specs are 19x9.5 and 19x10.5. The offset is 19. What kind of tires and what tires can I run? Preferably the biggest, most aggressive sized tire.
Thank you!
      01-23-2017, 10:30 PM   #2
chief
chief's Avatar
Drives: 2008 Melbourne Red M3 Coupe
2008 BMW M3  [9.51]
While I will defer the wheel & tire experts here, I would think you could run 265s up front and 285s out back without issue. You might be able to plus those up to 275/295 but I am not familiar with 19mm offset and how that will effect clearance inside and outside of each corner. Another piece of info that group will want to know is ride height and suspension set up (stock vs lowering springs vs full coilovers).
      01-23-2017, 10:33 PM   #3
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
Thanks a lot for the information. I'd like to lower it, haven't decided on what I'm going to lower it with. I'd like to be at least 285s in the rear. If I could do 295s that'd be great.
      01-24-2017, 01:56 PM   #4
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
I'm thinking of h&r springs but if there's a more recommended coilover I'm open to suggestions. Thanks a lot everyone
      01-24-2017, 01:59 PM   #5
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Make sure you change your rod bearings before your new wheels blow up your motor....
2014 M5 6MT
6ixSpd6033.00
SDPLV493.00
      01-24-2017, 02:06 PM   #6
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
SDPLV493.00
      01-24-2017, 02:08 PM   #7
opihi5
opihi5's Avatar
Drives: 2011 m3
2011 BMW M3  [10.00]
You can do 295/30 in the back but I wouldn't recommend it. I debated doing huge sizes for awhile but ended up going 255/35 and 275/35. In order to get the grip I wanted I got ad08r's and from a 3500rpm launch I get no tire spin and probably a 0-60 in the low 4's or even below. Stiffer sidewalls feel much better than the oem tires.
Note: I rubbed for a few days on them...I am lowered. Doesn't rub anymore haha
      01-24-2017, 02:09 PM   #8
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
Do you think a 285/35 would rub? With the offset being 19. I'm more worried about the front. I got a flat tire and I put stock m5s wheels that I had laying around. And they rub 255/40/19
      01-24-2017, 02:11 PM   #9
opihi5
opihi5's Avatar
Drives: 2011 m3
2011 BMW M3  [10.00]
285/35 will rub in the rear.
I went with dparm's setup and no regrets
      01-24-2017, 02:11 PM   #10
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
But then a 285/30 wouldn't? So the issue is the aspect ratio?
      01-24-2017, 03:17 PM   #11
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
Wait who's dparm lol, I'm going to search him
      01-25-2017, 07:51 AM   #12
rdoctor
Drives: 991.1 GT3
2009 BMW e92 M3  [0.00]
The other piece of the puzzle is brand of tires you chose because not all 265/35 : 285/35 tires are the same between brands. Some have a more square profile than others and will rub with aggressive offsets and lowering.
Lot's of good info here: http://www.m3post.com/forums/showthread.php?t=475902
here: http://www.m3post.com/forums/showthread.php?t=522139
and here: http://www.m3post.com/forums/showthread.php?t=932695
991.1 GT3
SOLD: e92 M3 6MT, Jet Black/Black
Dinan: Software Tune | CF Intake | Exhaust | Pulley Kit | Stage 1 Suspension | Pedals /// BBS e88 18x9.5 et19; 18x10.5 et19 on PS4 265/285 /// Lux Angel Eyes
      01-25-2017, 09:24 AM   #13
6ixSpd
Save the manuals!
6ixSpd's Avatar
6033
Drives: '16 M3, '23 718 Spyder
Check the Wheel & Tire Section. It's there for a reason.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      01-25-2017, 10:11 AM   #14
itsnotq
itsnotq's Avatar
49
Drives: 2010 E90 M3
Thanks a lot, I started reading the thread last night and I feel like I'm getting very knowledgeable lol
      01-25-2017, 09:51 PM   #15
shimmy23
F15 daddymobile
shimmy23's Avatar
2356
Drives: GS X5
people don't use those sections anymore
m3post
