BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      02-27-2017, 12:32 PM   #1
hamletl
Drives: 2016 M4- Tanzanite Blue Metall
weird vibration with new motormounts
Hey guys! Any help would be appreciated. I switched my motor mounts out to the Vibra-Technics street mounts about two weeks ago. After the install everything was fine and there was a slight increase in vibration through the floor and steering wheel like I expected. However, after about 250 miles, between 2k and 3k rpm the car rattles significantly. The only reason it worries me is because its not how it was last week. Do motor mounts need time to settle in? Is what Im experiencing normal? If you need any other info I'm happy to provide anything I can. Thank you so much for your help!
moved from engine and transmission subforum as this may be the more appropriate community.
      02-27-2017, 03:26 PM   #2
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Maybe the mounts are not torqued correctly or seated properly if there is a locating hole.
      03-10-2017, 12:46 AM   #3
tlow98
Drives: 2009 E91, 2014 F15 x35i
Sounds like the bolts have come loose to me. Get a visual on them.
      03-10-2017, 12:59 PM   #4
Datka
Datka's Avatar
450
Drives: 2009 M3 ,2021 M340i
Definitely not normal. You should take your car back and let them look if bolts are loose or mounts are seated properly.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
      03-14-2017, 07:34 PM   #5
e92zero
Drives: 2011 E92 BW
what others said above. I have the Vibra-Technics mounts as well and 46000 miles later, it's still the same as the day I put them on. Good luck.
      03-14-2017, 09:32 PM   #6
aworkmon
aworkmon's Avatar
15
Drives: 2009 E92 M3
When I put mine in the engine actually sat a little higher causing the exhaust to vibrate against the heat shields. I had to bend some of them back to stop the vibrating. Also recheck the torque on the mounts. I also had to remove one of the o2 sensors as it was vibrating against the frame.
      03-22-2017, 10:35 AM   #7
hamletl
Thanks guys! It has some heat shielding that was making the metalic noise I was hearing which was great to figure out. The more violent vibrations dissipated after I re-torqued the mount bolts. The mounts are incredible and I love the new feel!
m3post
