03-02-2017, 04:21 PM | #1 |
Rep 37
Engine rebuild shops - Sydney?
Hey all, recently made a post on the engine/drivetrain area, and as part of that problem (something went wrong during rod bearings install) I now need someone to pull down and inspect the engine for damage.
Original thread here: http://www.m3post.com/forums/showthread.php?t=1358010 Question for the Sydney-siders amongst us... can anyone recommend a shop for such a job? Anywhere in Sydney - don't mind. Just want good, careful work. Are there any forum sponsors in Oz (that do this)? Couldn't see one in the list... Thanks for anything anyone can offer. |
03-02-2017, 11:35 PM | #2 |
Rep 1,107
Sorry to hear about your issues ...... I'm not Sydney based but I often read on the Aus section of the forum that Advan Performance in Auburn know their stuff. I understand they have done many RB replacements on the S65. Good luck with yours
03-03-2017, 02:58 AM | #4 |
Rep 37
Thanks for the replies guys,
I have tried Advan (too busy for the next few months), and several others. Haven't tried Bromspec yet - but I will. Thanks SWM I am surprised at how difficult it is to get someone to even have a look at it. Seems everyone is so busy that it's more trouble than it's worth. Maybe I'll just trade it in for a Hyundai No... no, I won't be doing that... |
03-03-2017, 02:59 PM | #5 | |
Rep 57
Drives: 2011 E92 M3 DCT
DMC38049.50 |
03-04-2017, 01:10 AM | #6 |
Rep 170
Alistair - Bromspec
Stu - BMR Another option may be to have the workshop drop the engine and ship it to Southern BM. They are brilliant, probably the most experienced builders of the S65. The other thing to seriously consider here is that the engine is toast. With the amount of noise it was making I would almost lay money on the bores and crank being stuffed. Unfortunately being Nikasil/Alusil you can't just hone and sleeve it like an old 350 small block. Downside - The hassle and wait for a refurb block (No new ones left) Upside - The opportunity to mic the crank and spec size the mains and conrod bearings. Or maybe even throw a bullet proof Dinan 4.4 stroker in there and never worry again Last edited by OzCraig; 03-04-2017 at 05:25 PM.. |
DMC38049.50 |
03-05-2017, 03:50 AM | #7 |
Rep 105
I've always wondered how the crank surface finish is corrected, big end bores are measured (then machined as required if out of spec) as well as clearances checked & adjusted when the rod bearings are replaced with the engine in the car. If someone tells me they check with plastiguage, you've got to be kidding!
Given the state of some the bearings removed, these issues would need to be addressed prior to installing new bearings (else the new bearings will be no doubt compromised)..... btw, is the core issue here - bearing construction, bearing clearance, bearing concentricity, oil viscosity, oil timing, oil pressure, oil volume, rod sizing, crank surface finish, tune or other? No way I'd be just changing big end bearings without understanding what the root cause is, & prepping appropriately, let alone just replacing in situ with new (improved no doubt) bearings (irrespective of the bearing coating used - which does generally help to some extent). Just as a basic question, I assume at least a bearing micrometer is used to measure before & after bearing thickness? Maybe the engine builder can provide you at least those specs ...... Someone told me measure twice, install (or was that cut) once. Seems like amateur hour going on here. You need an engine builder who knows what he is doing, not an "installer". Last edited by fontana302; 03-05-2017 at 03:55 AM.. |
03-05-2017, 05:54 AM | #8 | ||||
Rep 170
You have a lot going on here. To understand what you are asking let's break it down.
When the bearings are removed you both visually inspect and mic the crank surface to check for any major wear issues. Being that the bearings are designed to be softer than the crank if you change the shells out before they spin/go bang the crank is usually fine. However, if the crank is damaged then it will need to be pulled out and linished or replaced. The plasti gauge check is often required for warranty purposes and is used to check torque down crush. Quote:
This is where people on this forum have strong opinions on whether or not the replacement bearings on the market are a 'fix' or not. Personally, even if they are not the be all and end all I am happy to do them if it buys me another 100,000km on the car. The choice is yours, it's all about risk management. Quote:
TLDR: Short answer, yes they are gauged. The measurements are all there, have at it. Hope this helps, Craig |
03-06-2017, 04:08 AM | #9 |
Rep 105
Thanks Craig
Just so you are aware, a big end bearing is a conrod bearing (sometimes also shortened to rod bearing)......., not a main bearing. It's the big end of the conrod. The little end of the conrod is the end with the piston (gudgeon) pin. https://en.wikipedia.org/wiki/Crankpin No confusion here. I stand by everything I've said...... I think my standards are just a bit higher than most. Last edited by fontana302; 03-06-2017 at 04:24 AM.. |
03-06-2017, 03:56 PM | #10 |
Rep 170
Yeah I get that, I build engines. I think it's a nomenclature out of phase situation happening here
Nothing wrong with that at all. I am sort of in the same boat as you. I would REALLY like to know definitively what the root cause of the issue is before throwing another set of shells in there and perform a permanent fix. However the thought of a 15-20k bill to replace a windowed block is staggering. Something that may interest you is the results gleaned from Dinan's stroker builds. They do a 4.2, 4.4 and 4.6L stroker upgrade. Not a single one of them has failed that we could find. Now all Steve is doing is replacing the crank, rods and pistons. This leads me to believe that the issue of a clearance tolerance may be correct as by Dinan mic'ing and spec sizing the shells correctly the problem seems to be mitigated. An anecdotal piece of evidence is a close friend of mines Dinan 4.2 M3. He has had it for years now, daily drives it and wails on it. Never had a issue with the engine in 50k of abuse. |
03-06-2017, 07:01 PM | #14 |
Rep 170
Quick search reveals Southern are Aussie reps for Dinan.
I'm sure they would do it nowadays though. They have a lot of experience with the S65. Group buy? |
03-07-2017, 03:59 AM | #16 |
Rep 105
Thanks Craig, we are on the same wavelength here.
I've been using coatings on cranks, rods, pistons, bearings, valves for close on 20 years now (have a set of Polydyn coated titanium rods from the mid 90's new still in the box). A coating will never save a design/clearance issue. |
03-10-2017, 04:42 AM | #17 | |
Rep 1,464
Drives: BMW X5M Comp
03-10-2017, 11:39 PM | #18 |
Rep 37
Thanks for your replies guys (and girls...)
I'm going to drop the car down to Alastair next Friday to start the biopsy Hopefully he can get to the bottom of it and get her up and running again soon. Fingers crossed. Will let you know how it goes |
03-11-2017, 12:16 AM | #19 |
Rep 1,464
03-16-2017, 03:32 AM | #20 |
Rep 2,224
I've had my engine rebuilt twice now, both times it was stroked and re-sleeved.
First time was in the US and second time was here in bris. The first time I had the rebuild (prob 5 years ago?) no one in Australia would touch it or knew what to do. More recently, though, the workshop in brisbane has now rebuilt quite few and I would recommend them. |
03-19-2017, 03:11 AM | #22 | |
Rep 37
Will let you know when I know. 'Tis an anxious wait... |
