03-22-2017, 08:45 AM | #1 |
Rep 984
Brake pads and fluid for street car doing HPDE
Need some brake job advice for my street driven M3 I'm planning to do my first HPDE with soon. I'm currently on factory pads and rotors and have a few questions:
First: what is a good hybrid brake pad to use? I was looking at the StopTech Street performance pads. But dont know if that's strong enough for track duty, but I also don't want a pad that will wear down my rotors too heavily since it's a street car (not daily driven though). I also saw the Hawk HP Plus pads for more money but maybe they're too much for stock rotors? Secondly: Do I have to change the rotors at the same time, or is it ok to put new hybrid pads on my factory rotors and just bed the pads in? I will be checking the thickness of my rotors to make sure they are still within spec, does anyone know what is the minimum the rotors should be? Lastly: Will any higher temp DOT4 fluid do the trick? Or is there a particular one I should buy or that you guys like to run? Thanks!
2004E46M36MTCBCinn 'Clubsport'
03-22-2017, 10:01 AM | #3 | |
Stop the hate, get a V8
3853
Rep 8,625
For a hybrid pad, your best bet as far as availability and performance will be the Ferodo DS2500. It might squeak a bit when very cold. I have used these as a hybrid on multiple cars, including my M3. Even Dave at Zeckhausen Racing will recommend this. No, you don't need to change the rotors, but you will want to bed the new pads in. Thickness is actually printed on the rotor itself. For fluid, go with Castrol SRF.
Past: 2011.5 M3 sedan ZCP |
BigRussia152.00 |
03-22-2017, 10:31 AM | #4 | |
Rep 984
Will the Ferodo pads wear the rotors significantly faster than regular street pads? I'm sure itll wear more but I want to know if its going to be a concern since I will be driving with these pads 100% of the time
03-22-2017, 10:53 AM | #5 |
Rep 403
As long as your brakes are in good condition I would just do the HPDE with a stock setup. Once you get into tracking more often then you will require upgraded brake fluid and pads.
Go have some fun first then spend some of your money if you continue to advance you skills and do open tracking sessions. |
03-22-2017, 11:08 AM | #6 | |
Rep 1,325
Just go have fun.
03-22-2017, 11:53 AM | #7 | ||
Rep 984
And the cost isnt really much of an issue for me, I already have the SS lines, just want to get a pair of front pads and upgraded fluid so maybe all under $300. Also want to replace my pads before they hit the wear sensor and then those needing to be replaced too. Going off what you guys saying how about maybe running the Hawk HPS pads? Seem to be a good performing street pad that while not intended for track use seem to be able to handle light track duty?
elim11423.50 |
03-22-2017, 11:58 AM | #8 | |
Rep 5,507
Right now I'm using Project Mu HC+ and Project Mu G-four 335 fluid for track use. The pads squeal like mad on the street but no deposits.
Auto Detailing Enthusiast!
03-22-2017, 03:09 PM | #9 |
Rep 984
Yeah im looking for the balance of street able but trackable pads for my street car, so alot of squeal and dust is not what im looking for since im leaving the pads on.
03-22-2017, 03:25 PM | #10 |
Rep 3,994
I don't think you will find the balance you are looking for.
Track pads squeal, street pads don't perform as well as track pads. Many run two sets of pads and swap them before going to the track. Which track day are you doing and at what track? I'm thinking of going to a few soon.
03-22-2017, 03:31 PM | #11 | |
Rep 5,507
Anything that'll last through a track day will squeal at least a little. If you're ok with subpar braking and pulling out of the track sessions early, you can get away with street/track pads... just be aware that some are friendlier than others when it comes to overheating and pad deposits. If you haven't tracked before, you can just flush the brake fluid with high temp fluid and try the stock pads. They'll fade quickly but usually do ok for beginner sessions. I ran them before. With any pad, be sure to do some cool down laps before exiting. Last thing you want is pads cooking on the rotor when you park.
03-22-2017, 07:45 PM | #12 |
Rep 984
I just meant I dont want ALOT of squeal, like a massive embarrassing amount. Im cool with a little squeal that all performance/track pads make. Even my current pads, that I'm assuming are factory OEM, squeal when I come to a stop after getting heat into them during spirited driving (are the OEM M3 pads expected to squeal or do I possibly have upgraded pads already?)
Sounds like the Ferodo DS2500 are a good balance that I'm seeking, but then I see some saying they suck on the track (but maybe those are hardcore track guys) tdott - Im planning on doing the PDG HPDE in May at Homestead, its posted in the SouthEast region forum.
03-24-2017, 11:08 PM | #15 | |
Rep 3,303
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
03-24-2017, 11:16 PM | #16 |
Rep 3,994
03-25-2017, 10:22 PM | #17 | |
Rep 3,303
Cheers, e46e92
03-26-2017, 02:22 PM | #19 | |
3853
Rep 8,625
I have never run the HP Plus, but a coworker of mine has an E46 M3 with those pads and it sounds like a garbage truck. It was pretty annoying to ride in it. The Ferodo pads will eat through the rotors faster than a stock pad, yes. That is the trade-off for better braking. The OEM rotors are pretty beefy so it's not like you're going to hit minimum thickness in a month of driving. The DS2500 is still considered a hybrid pad so it's not like running a track pad that is absolutely brutal to rotors when it is cold. I would not overthink it. Focus on developing proper (and safe) technique -- this will let you use the brakes more effectively. Novices often overheat their brakes.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 03-26-2017 at 03:17 PM.. |
03-26-2017, 09:37 PM | #20 |
Rep 3,303
Contrary to your self delusions, your opinions are not the only ones that count. You want to decide who can post and what, feel free to apply as a moderator. Actually, don't, you won't be approved.
Cheers, e46e92
03-26-2017, 10:06 PM | #21 |
DSC Off!
307
Rep 718
You should be fine with stock pads if you've never tracked before. If you have any concerns, go with the Stoptech Street performance. They check all your boxes and will be fine through your first few track events. If you get the track bug after 2-3 events, you'll need to move onto different pads for track and street. Mic dropped.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
e46e92love235.50 |
03-26-2017, 10:11 PM | #22 |
DSC Off!
307
Rep 718
Forgot to mention to put a sock over your power steering reservoir as it will spew fluid all over your engine bay otherwise.
