04-24-2008, 10:31 AM | #3 |
Rep 789
no when you shut off the car the ipod doesnt affect the battery at all. once you turn it back on it begins charging the ipod battery again..
E92 ///M3/Alpine White/6MT/Tech/VRS Boot Lid/UUC SSK/H&R Sport Drop/Hamann lip/ Remus Race Exhaust... |
04-24-2008, 10:40 AM | #5 |
Rep 146
No actually on all bmws there is power when the enginge is turned off. Your IPOD is still getting charged when the car is turned off. It can drain the battery. Cell phone chargers also work when the car is turned off.
04-24-2008, 10:59 AM | #6 | |
Rep 4,144
If you have the option, the iPod, or other USB audio device, can be plugged into the USB port for power. I do not believe this to be the case but the USB socket might be powered while the ignition is off. Plug the iPod in with the engine and ignition off and look at the battery symbol in the upper right of the iPod display. If says that it is charging then the USB port is powered when the car is off and then you should not leave the iPod in. Otherwise, it's OK. Leave it. For general audio devices plugged into the audio port only, there is no power either way then it's is OK. Leave it.
2017 F80 YMB.
04-24-2008, 12:14 PM | #8 |
Rep 1,429
And even if it was dead and you left it charging, it won't drain the battery. I promise your battery is stronger than an iPod battery.
04-24-2008, 12:39 PM | #9 |
Rep 5,124
i gotta stick up for the OP a bit here. i don't think he was worried so much about it charging the iPod but whether it could potentially drain the battery. you are right that your method will give that answer, but i think that the question was legit.
04-24-2008, 01:29 PM | #10 | |
Moderator / European Editor
1545
Rep 6,754
BTW: No more climbing? Must have missed that... Best regards, south
04-24-2008, 03:12 PM | #11 |
Rep 167
hey dangoma,
I forgive your misguided comment as I am sure in person you would not be so stupid and rude. Do you think you are helping anyone here? Back to the question- by the way I have read every page of all the manuals. I want to just hook up a spare iPod to the car and just leave it there for good. If I plug the device only in the USB cable (key not in ignition, no CA), the iPod Does POWER up. Just plugging in the round jack does nothing. Therefore am I ok if I leave the round jack in permanently and just use the USB cable when I want to listen to the iPod? And yes it is the car battery I am concerned about!! Thoughts? |
04-24-2008, 04:18 PM | #12 | |
Your Mom
13
Rep 234
You right im not rude, just annoyed with people asking questions that make no sense, given you can try this on your own. As for stupid, I really am not going to get in an argument with you on that, since clearly you must be. Someone a few posts up ALREADY answered this question. READ! |
04-24-2008, 04:55 PM | #13 |
Rep 167
I tried to be politically correct, now I just need to be blunt dangoma: You are a f---ing a--hole with obviously no life. Please leave this thread alone.
04-24-2008, 05:00 PM | #14 | |
Rep 1,020
So... the iPod neither drains the BMW battery, nor does the BMW drain the iPod battery. |
04-24-2008, 05:21 PM | #16 | |
Rep 1,274
I guess this is another plus for the "flash drive way". PS: I'm asking as I still don't have my car, so I don't have anywhere to test my "theory". |
04-24-2008, 08:15 PM | #17 |
Rep 431
A car battery would blow up an iPod battery, but if the iPod screen stays lit then it could drain the car battery just like any other light.
04-24-2008, 11:54 PM | #18 |
Rep 2,484
I would just leave it plugged in if it's your daily driver and just unplug it to be safe if you are ever away from your car for an extended period of time.
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights | |
