      03-27-2017, 06:15 AM   #1
TechieCarGuy
Drives: 2011 E91, 2008 Z4
No SOS or BT Phone after CIC removal
I recently pulled the CIC head unit out of my 2010 135 in order to install one of Technics wiring harnesses and upon re-installation I got the no/SOS service error and now can not connect to my phone via BT, as if something didn't get connected correctly.
I pulled everything out again and check and all connections on the back of the CIC, but I am wondering if the MOST connectors are finicky and might give such an error if not seated correctly, or am I looking at a bigger problem. Or has my TCU gone bad all of a sudden?
Also, I loosened my center console, in order to run cables to the back of the car (RCA and remote lead from Technics harness) and discovered a Most connector and another plug at the rear most portion of the center console (facing the backseat). Neither were connected to anything but I am wondering what they are for and whether or not I overlooked something and one or both of these are my problem if they were originally connected to something and I accidentally disconnect, however there are only one end of said cables under the console and nothing else to plug into them, that I can see.
      04-04-2017, 03:06 AM   #2
Duesentrieb
Germany
9
Drives: E81 116i, F31 LCI 320d
Hi,
sounds like a problem with the MOST. Have you plugged in them correctly? Have you removed the MOST cables from the connector? If so, you may have mixed up both wires: one is the input and one is the output.
Normally there isn't any MOST connector under the center console. Are you sure that it is MOST? Can you take a picture?
Greetings
Daniel
1addicts
