04-12-2017, 07:53 PM | #1 |
Rep 132
hairline headgasket leak? or something less serious
So it started when I noticed the coolant was a bit low. I was just looking over things I didn't have issues with the car. It was a bit low so I I added a bit (like a drinking glass amount) and a few months later it was down again. I would top it off and notice it was overflowing from that little port on the side of the expansion tank, the channel its supposed to flow out of if the cap builds up too much pressure. I did once overfill it to the second bubble when the car was cold so at first I assumed that it was the lill bit of extra coolant but way more came out by now. I changed the radiator tank cap and had noticed a sporadic 2b59 code but no CEL light. Today I opened the bleeder screw incase there was air in the system and will properly top it off when cold.
Any ideas on what this could be. should I try changing the tank maybe? I dont know how the tank can be at fault, the coolant is simply evacuating from the tank from pressure or air. All i can do is check compression unless you guys got anything. |
04-12-2017, 11:27 PM | #2 |
Rep 3,140
Drives: 2014 M5 6MT
check for leaks around the thermostat housing and radiator hose connections. It may be seeping coolant and not a full blown leak just yet. hence the slow leak. I've never seen head gaskets fail on the S65. x
2014 M5 6MT
04-13-2017, 01:09 AM | #3 |
Rep 132
I know where the leaks at. It's the reservoir channel that's designed to expel coolant. It's that channel right off of the reservoir cap neck. It's working as intended. It's there to aim the coolant overflowing from the tank downward so it doesn't spray the engine when there's a small overflow situation. My problem is finding the reason for excess pressure in my cooling system. Can the coolant overflow due to a sticking thermostat maybe? I do have the fault for a thermostat being thrown. It's been Coming and going for a year. Never threw a cel light I always found it once in a while when playing around with the diagnostic software. The fault just says "thermostat monitoring" I don't know if it's going off cause the temps are rising slightly but not enough to throw a check engine light soon. Coolant is overflowing very slowly. I can go months withought adding antifreeze and I never even had a coolant light come on yet.... that's why I'm maybe suspecting a hairline crack in the head gasket. unless maybe the coolant tank is slightly worn and even a new cap is just a tad too loose. I'm at 60k miles on the car btw
04-13-2017, 07:10 AM | #4 | |
Rep 3,140
Drives: 2014 M5 6MT
Secondly, the coolant system on these cars are not designed to bleed of coolant in anyway. The reservoir cap is designed to maintain 16 psi of pressure in the system, and in the even of overpressure, bleed of vapor. If you are leaking coolant from anywhere, that part or connection is defective. How do you know there is excessive pressure? Have you tested the coolant system with a pressure test with a gauge? What, other than speculation, have you done to diagnosed the condition? Again, I've never seen a head gasket fail in any way on an S65. You would have to MASSIVELY overheat the engine to do so. The engine would suffer way more damage from an overheating situation than just a bad head gasket. My advice to you, stop speculating what the problem is, and take the car to your favorite dealer or indy shop and let them diagnose it.
2014 M5 6MT
04-13-2017, 02:52 PM | #5 | |
Rep 132
