04-13-2017, 02:25 PM | #1 |
Rep 459
USB capacity limitation?
I have a 2012 MY M3, with combox, and a USB port in the glovebox.
Is there a maximum capacity limitation for USB memory sticks here? |
04-13-2017, 03:53 PM | #2 | |
Stop the hate, get a V8
3853
Rep 8,625
As far as I know, no. FAT32 has a max size of something like 2TB.
Past: 2011.5 M3 sedan ZCP |
04-13-2017, 05:21 PM | #3 |
Rep 459
04-13-2017, 09:05 PM | #4 | |
3853
Rep 8,625
It's possible BMW hard-coded a limit for whatever reason, but I thought I've seen people on here use 32GB and larger drives without any problem.
05-07-2017, 12:10 AM | #6 |
Rep 93
I use a 64GB USB key in the armrest with about 45GB of music on it, works fine, but takes a while to load the artist/album info when the car is first turned on.
05-07-2017, 09:22 AM | #7 |
Rep 217
Are you talking about the armrest, or the glovebox. The glovebox is for loading music into the HD and has some ridiculously low capacity, like 2GB or some such, and will not read an iPod or thumbdrive on-the-run.
As others have said...I use a 32GB thumbdrive, in the console. -Mark in St. Louis |
05-26-2017, 02:55 PM | #8 | |
Rep 459
05-26-2017, 09:35 PM | #9 |
Save the manuals!
6032
Rep 6,753
The glovebox port definitely has more than 2GB capacity as it is used to upload GPS map data. I've used a 256GB capacity stick there without issues for loading map updates.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-26-2017, 09:44 PM | #10 |
Rep 217
There may be a separate partition for maps...but...for music, it wouldn't save the contents of the 32GB thumb drive I use in the console...loaded maybe 4-5 playlists, tops.
If someone knows differently, I would love to hear how to load the 32GB jump drive onto the HD. -Mark |
05-26-2017, 09:51 PM | #11 | |
Save the manuals!
6032
Rep 6,753
05-26-2017, 10:00 PM | #12 |
Rep 217
I just went on a search for older threads...Looks like I was misinformed...I found (2) different references (from (2) different BMW models) stating 8GB and then another stating 12GB...
Still too small for my "library", but big enough for a reasonable playlist...that's assuming the maps/etc. don't eat up a bunch of capacity. -Mark |
