BMW M3 Forum (E90 E92)
      05-11-2017, 10:15 AM   #1
Nazty Naze One!
Nazty Naze One!'s Avatar
Drives: 2010 M3 E92
Hi everyone. I'm planning on putting my M on some KW HAS spring sleeve overs, along with a Dianan sway bar up front. The wheels will hopefully be the vorsteiner ff101's, which run 9.5 in the front and 10.5 in the rear.
I'm wondering if I'll need Camber plates or adjustable control arms in the rear. In other words will I need to adjust for toe or camber?
I'm looking to avoid all these costs so any advice or recommendation would be helpful.
Thanks
      05-11-2017, 11:08 AM   #2
opihi5
opihi5's Avatar
Drives: 2011 m3
2011 BMW M3  [10.00]
Thanks
There's a lot you have to take in account, will you track? Is the car DD?
Camber plates are nice for taking advantage of tires and having more adjustability, but if you want to avoid the extra cost you could just pull the alignment pin and get close to -2.
For street I'm on springs and GC camber plates.
      05-11-2017, 11:19 AM   #3
Nazty Naze One!
Drives: 2010 M3 E92
Thanks
Thanks
Yep just for daily street use.
      05-12-2017, 08:23 AM   #4
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
For street use you will be perfectly fine with the stock rear bits. For the front you should not need camber plates - I was able to get -2 degrees in the front with KW HAS kit with everything else stock and the alignment pins still in. And it's not like you even need that much.
      05-12-2017, 12:06 PM   #5
Nazty Naze One!
Drives: 2010 M3 E92
Cool. Thanks for your input
m3post
