05-14-2017, 01:17 PM | #1 |
Rep 3,386
Car feels unstable at high speed
My 2015 M3 with active suspension feels unstable above 100mph (tested in Mexico). I am recently coming from an e92 335i and that car felt very planted all the way to 155. When I am going 100+ on a perfectly flat and straight high way in the m3 I have to make a lot of steering corrections just to keep it straight and it doesn't feel as planned. The sensation is almost like is a gust of wind were blowing the car from side to side. I have tried all the different steering and suspension modes, but the second I go over 100mph the car starts to feel twitchy and not planted. The tires are filled to 33psi all around (door insert recommended tire pressure) which honestly seems low to me would think it should be around 38 front 40 rear. I also thought it could be an alignment issue but the car tracks perfectly straight if I let go of the wheel. Any thoughts on this issue would be greatly appreciated. Thank you
05-14-2017, 01:25 PM | #3 | |
Rep 2,825
I am suspecting that the tires are under inflated for such a speed. |
papasmurf_m3454.50 |
05-14-2017, 01:26 PM | #4 |
Rep 5,056
You know what happens when one tire is off by 1/2 PSI
12
SakhirM410784.50 GrussGott18198.00 F831355.50 mdemon245.50 myzmak2416.50 behindthen0thing839.50 stillplayswithcarss1595.00 unfoundnemo1923.00 DML967.50 Silverlining_m21743.50 ried793.00 dezzracer1185.50 |
05-14-2017, 01:27 PM | #5 | ||
Rep 3,386
05-14-2017, 01:40 PM | #8 | |
Rep 2,825
the faster you go, the more air you need in your tires. |
unfoundnemo1923.00 The_Werm214.00 |
05-14-2017, 05:23 PM | #12 | ||
Rep 1,728
~ 24 M4 Comp
~ 24 X3 M40 ~ Prior BMW's - Too many to list here (27) |
05-14-2017, 05:53 PM | #13 |
Rep 435
Drives: 2017 BMW M4CP SO
behindthen0thing839.50 |
05-14-2017, 06:29 PM | #14 |
///Multiple
2993
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
On our Euro Delivery in May last year, my wife and I both top-ended my M4 at 271 km/h (168 MPH) on the German Autobahn and both times the car felt absolutely solid as a rock. The car was brand new and bone stock.
If you're unstable at 100+, you definitely have something going on with your car.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
05-14-2017, 06:34 PM | #15 |
///Multiple
2993
Rep 4,243
Not exactly true. If you check the sticker in the driver door jamb or your Owner's Manual, depending on which wheels and tires you have, BMW recommends one tire pressure (31 psi front and back for my M4 with 19" wheels) for speeds up to 100 MPH, and a higher tire pressure (34 front and 37 rear) for speeds 100+.
05-14-2017, 06:40 PM | #16 | |
Roofless & Ruthless
1356
Rep 1,480
Drives: 2015 AY 6MT F83
Bad road? These cars can get pretty bad tramlining given 255s on the front.
05-14-2017, 06:56 PM | #17 |
Rep 4,203
I have a small vibration that comes and goes but this is the most stable car I have ever owned. The faster you go the better it feels. I have been adapting it with the JB4 and E85 doing 4:30 am early morning 4ht and 5th gear pulls....60 to 120 and 140. That thing just glides...even with the vibration
bsmf8x778.50 |
05-14-2017, 07:53 PM | #19 |
Rep 3,386
Should have clarified I am running the stock MPSS tires with about 2,000 miles on them. I think the issue might be tramlining, since I did about 110ish on a different road in Mexico today and the car felt very stable. The original road I was on seemed very smooth so I don't know why that would have happened. Is everyone running 33psi on the pilot super sports? That just seems really low to me
F831355.50 |
05-14-2017, 08:02 PM | #20 | |
Rep 3,999
32-33 cold PSI is the sweet spot. My dealer had mine up to 36 when I picked up the car, and the handling was terrible until I dropped them down.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
F831355.50 |
05-14-2017, 08:05 PM | #21 | ||
Rep 3,386
