05-21-2017, 05:50 PM | #1 |
Rep 61
Looks like you can code auto start up of Sport Mode
I recently got the BimmerCode app for iPhone and I noticed that there is an option to not only default "on" Eco Mode & Comfort, but I also saw that Sport mode was included!
I haven't tried it, because I simply am not interested in starting my car in Sport mode all the time, but every other coding option on this app works great! So I don't doubt it for it works. Just make sure you also download the BimmerLink app (from the same publisher) so you can clear out fault codes after coding your X5... it's free after all. You do need to unlock the coding feature on the BimmerCode app, which is cheap, and you will need a $20 vGate wifi II apadter (available on Amazon) but for the ease of use, it's well worth it. Customer support is also great as the publisher usually responds the same day with any questions that you may have. Highly recommended!
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package |
05-22-2017, 02:36 PM | #2 |
Rep 8,364
You can either code default driving mode, or to remember EcoPro, Comfort, & Sport startup.
06-01-2017, 04:33 PM | #3 |
Rep 8,364
Free?
06-01-2017, 07:01 PM | #4 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Anybody know how this product compares to Carly?
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
06-01-2017, 09:14 PM | #5 |
Rep 152
I use bimmercode instead of Carly... the interface is simple yet offers advance pro mode.
Combine with a vgate adapter ($20) it's a lot cheaper than Carly plus the developer is on top of each support questions. I highly recommended
Jeff
Current Ride - 2016 Toyota RAV4 Hybrid - 2014 X5 xDrive35 M - 2013 ML-350 (Gone) - 2012 Audi Q7 TDI (Gone) |
08-10-2020, 08:00 PM | #6 |
Rep 38
Coding to default to Sport flat-out doesn't work (2016 F85). I've read old lposts that it isn't possible as well but assumed since that post was 5 yrs ago it would be doable by now but I've tried many, many times & it won't stick. Same with remembering last mode used.
08-10-2020, 09:59 PM | #7 | |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
463
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
08-10-2020, 11:27 PM | #8 |
Rep 11
I’m able to code through BimmerCode to start up in Sport mode (2014 35i). You have to code it in two different modules though to make it stick. Don’t recall off the top of my head but it didn’t need expert mode to do it and is pretty easy.
08-11-2020, 04:29 AM | #9 |
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
If you could let us know which modules they are next time you use the app that would be great..
08-11-2020, 07:45 AM | #10 |
Rep 220
08-11-2020, 07:53 AM | #11 |
Rep 25
I also have successfully coded it to start in sport mode. It works great.
08-11-2020, 08:06 AM | #12 | |
Rep 289
2014 X5 35i Sophistograu A90 (Dark Graphite) Terra Dakota
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
skoold2003791.00 |
08-11-2020, 10:45 AM | #13 |
Rep 162
BM
08-11-2020, 03:59 PM | #14 |
463
Rep 2,002
Finally got mine to work thanks for the info
08-14-2020, 02:35 AM | #15 |
Rep 8,364
08-14-2020, 08:22 AM | #16 |
Rep 7,548
Ditto for working. I just coded my 2014 to start in Sport mode & also remember the LAST mode by using the regular side of Bimmercode...you have to code both the BDC & the ICM modules for this coding selection to "work".
And I also went into the EXPERT side & coded the sport mode to be "individualized" or "selectable". I have the NBT and standard suspension...so sport mode was an all-or-nothing selection...in that when SPORT mode is selected the chassis (steering only with a standard suspension since there's no special suspension options) & drivetrain both kick in. For those with the newer iDrive systems or if you have an adaptive suspension...your SPORT mode may already be capable of individualizing the sport mode by choosing chassis only, drivetrain only, or chassis & drivetrain. For some, selecting to always start in sport mode may not be desire-able if you don't want the "hopped-up" engine/transmission/throttle parameters in city/urban driving conditions. But if you prefer the tighter steering feel of sport mode...if you select CHASSIS ONLY for sport mode...this can get rid of the lighter steering feel of the default COMFORT MODE...and not have the elongated shifts, higher RPM, and throttle changes that come with the "drivetrain" parameters of sport mode. If your SPORT mode isn't selectable due to you having the standard suspension...you can go into the EXPERT mode of Bimmercode and code the individualization of sport mode. This is what I did this past weekend. \ This is what my SPORT mode screen originally looked like...I could not make any selections...and the chassis & drivetrain parameters was the default and only selection: After coding...the SPORT mode screen changed to the one below and gave me the option to make selections (individualize) the way SPORT mode behave: The images below show what I changed in the HU-NBT (1 of 2 modules that require coding) to make the changes above that allowed me to configure my SPORT mode (individualize) so that I could select CHASSIS (only), DRIVE TRAIN (only), or both CHASSIS & DRIVE TRAIN. I used the BIMMERCODE app & used EXPERT MODE to change settings in the HU-NBT & ICM control modules. Changes made in the HU-NBT control module: The images below show what I changed in the ICM module (2 of 2 modules that require coding) to make the changes above that allowed me to configure my SPORT mode (individualize) so that I could select CHASSIS (only), DRIVE TRAIN (only), or both CHASSIS & DRIVE TRAIN. 1.Open the ICM module then go into EXPERT MODE and select 300A DSC_ICM_Codierdaten
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-14-2020 at 08:35 AM.. |
08-14-2020, 08:42 PM | #17 | |
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
08-15-2020, 10:27 AM | #18 | |
Rep 7,548
If you have the standard suspension...then what you desire is what I showed how to do in my post above. If you have the standard suspension...if you select CHASSIS only in the sport mode selection...then the only thing that will be affected is the steering since your suspension has nothing to adapt to by it being the regular/standard suspension.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
08-15-2020, 04:21 PM | #19 | ||
Rep 7,164
08-21-2020, 10:45 PM | #20 | |
Rep 1,179
08-22-2020, 10:10 AM | #21 | |
Rep 7,548
You can see the screen shots below...but again, there on the regular side of Bimmercode where you just make the easy selections. The hard work has already been done by the developers of the app. I’m sure this is somewhere on the coding “cheat sheets”. You’ll have to google for them (hopefully not hard to find).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-22-2020 at 11:33 AM.. |
08-22-2020, 12:55 PM | #22 | ||
Rep 1,179
I have the cheat sheet but it's not on there.. the search continues. |
