05-23-2017, 02:34 PM | #1 |
Rep 243
Weight Saving Vert's only
Is there anything you vert guys do to help save some weight? I did some searching and found a lot of stuff regarding the coupe and sedan but not so much vert info. I do realize some vert/coupe stuff swaps over but I'm wondering is there is anything I can do to help close that 400lb + gap from the coupe's. I like my vert and I'm happy with it, Im just wandering how I can start shaving some real weight without doing things like $5k carbon fiber doors and such. I would like to clip off 200lb's or so If I can even if its just the usual stuff like a light weight battery and new exhaust etc...
Im asking about the stuff thats not so common I would say. |
05-23-2017, 05:43 PM | #2 |
Rep 1,612
Why yes, there is something you can do...so glad you've asked, and yes, you did come to the right place!
First find a local detailer to make your vert sparkle. Then list your car for sale. Next find a 2011 e90 ZCP with sunroof and buy it before someone else with a vert reads this and beats you to it. Finally, sit back, smile and enjoy life knowing you've got the best of both worlds! |
05-23-2017, 08:28 PM | #3 | |
Rep 243
Yes first post useless A sunroof is comparable to a vert like buying an 02 boxster and saying you have a porsche. |
SpartaEvolution178.00 |
05-23-2017, 08:32 PM | #4 | ||
Rep 1,612
05-23-2017, 09:39 PM | #6 |
Rep 243
05-24-2017, 01:37 AM | #7 |
Rep 12,736
there is no weight to be lost in the doors, all the cf doors available get rid of the side impact bars (that is where the real weight is, not the door cards or outer skin).
get a carbon trunk (-20lbs), light weight battery (-50lbs), carbon hood (-10lbs), racing seats (savings vary), keep your washer fluid at a minimum (-8 lbs), burger cabin filters (-8lbs), lightweight exhaust (-35lbs+), lighter wheels (-30 lbs total), lighter brakes (-40 lbs total), carbon driveshaft (-12 lbs). getting light and still looking good is expensive, but that wasn't the topic of discussion.
Instagram; @roastbeefmike
05-24-2017, 10:51 AM | #8 |
Rep 5,482
Yep. Pretty easy to lose 100-150lb. For instance on the vert if you're only using it as a 2-seater, put the windblocker up and pull those rear seats out.
Beyond that and you start cutting into functionality of the car. I personally would not attempt putting race seats in a vert because the belts are integrated in the seats. Other miscellaneous items: headlight washer fluid nozzles and pump: about 2.5lb, code it out; remove superfluous trunk trim, about 2.5lb-5lb (but be careful on a vert, lots of moving parts back there) In other words, other than wheels, battery, pulling the rear seats, and the exhaust stuff (especially because xpipes are both lighter and add 15-20hp) don't bother
05-24-2017, 11:56 AM | #9 |
Rep 243
yea im not willing to lose functionality, so ill stick to basics and as far as wheels I have the 19's and they are very light for an oem wheel so I doubt ill save 30lbs on wheels unless I go carbon fiber which ha this isnt that nice of a car lol.
05-24-2017, 12:33 PM | #10 |
Rep 5,482
You can drop 6-7lb per wheel using stock-sized Apex 18's for instance. Apex 17's (which fit over stock brakes) or 18" volks are good for a 30lb-ish savings over 220M's using stockish tire sizes.
Most people don't lose that much weight when they go to lighter wheels because they're also using heavier, wider rim widths with heavier, wider performance tires with stiffer, heavier sidewalls. But if you have the self-discipline to stick with an 8.5" or 9" front and 9.5 rear and 245-255 front and 265-275 rear PSS or Contis, the package stays nice and light. I wouldn't recommend chasing weight too much in the wheels though, you want a wide front wheel to make a fat car turn
05-25-2017, 10:38 AM | #11 | |
Rep 243
I think i somebody had the money making all carbon vert top parts would be the best along with the trunk. Anybody make a CF vert trunk? |
05-25-2017, 12:41 PM | #13 |
Rep 10,664
Stock wheels are heavy whether 18 or 19. Apex ARC8 are cheap and light. And as richbot says think about 17s if you really want to save weight (in which case you would be into performance and would not have bought an overweight vert) -- they clear stock brakes and tires are cheaper.
05-25-2017, 04:18 PM | #14 | |
Rep 243
If you go from a 255/35/19 to a 255/35/18 it'll be an overall inch difference, It's simple math to know this. Unless your referring to how you can get a 40 series sidewall for 18's compared to a 30 series sidewall when you go 19's, that is somewhat true but still kind of wrong considering your talking about the sidewall height which is a percentage of the width of the tire and then itll change sidewall height but not by much. Off topic- Even though the car does ride better with 18's. My Z coupe felt so much nicer with 18's with a bigger sidewall. Plus a harder ride doesn't always make a better handling car as stiff cars especially on backroads can get out handled all day by softer cars because they can soak up bumps. |
05-25-2017, 06:33 PM | #15 |
Rep 10,664
05-25-2017, 07:38 PM | #16 |
Rep 243
Well the car comes with optional different size wheels. Also on the track this is done by people to keep sidewall rigidness and get the lower center of gravity while maintaining the same sidewall flex. So to answer your question that's why its done its very basic since I'm now going to be a dick also. Plus you cant just swap out rims and change up tire sizes and get the same performance always as the bigger the sidewall the more flex it has. I'm not sure how else to explain it to you. Having said this I have worked for 2 different major tire manufacture's and have gone through courses on tires(which will make your eyes glaze over). Sure you can go to a smaller rim and a bigger sidewall but you'll lose rigidness to maintain the same overall diameter. Not saying rigid is always great but that's the basic facts of the situation.
05-25-2017, 10:11 PM | #17 |
Rep 10,664
Changing aspect ratio as needed to maintain the same diameter is a very basic part of changing wheel diameter. We all know this. I have probably been altering wheel and tire sizes longer than you have been driving, possibly even longer than you have been alive. Again, what you are trying to exaggerate or be pedantic about is basic stuff anyone can read about on tire rack or in a car magazine.
05-25-2017, 11:23 PM | #18 |
Rep 1,171
05-27-2017, 05:22 PM | #19 | |
Rep 243
05-27-2017, 05:24 PM | #20 | |
Rep 243
06-20-2017, 04:55 PM | #21 |
Rep 4,635
sell the car and get an E92
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
