06-16-2017, 03:13 PM | #1 |
Rep 22
Need help removing my E92 rear seats
E92 M3
I already removed the side cushions and the bottom cushions, just need help removing the folding cushions. What size are the two torx screws connecting the foldable seats? The space there is very narrow and I cannot fit any of my tools in there, does anyone have a special suggestion for removing them? Last edited by vvzzxx; 06-16-2017 at 09:39 PM.. |
06-18-2017, 10:12 AM | #2 |
BimmerPost Supporting Vendor
3769
Rep 2,912
Drives: 2011 E93 M3
You don't have to remove the support in the center of the rear seats. Once you remove the outer side mounts, separate/pull the seat backs outwards and away from each other. If you separate the seats far enough (requires some muscle and patience), then the large hinge pin will slide out of the other seat and allow seatback removal. Or at that point, if its easier for you, when you slide them apart far enough you can get your torx wrench in there to remove the center support.
07-02-2017, 03:29 PM | #3 | |
Rep 22
07-03-2017, 08:54 PM | #4 |
Rep 12,736
its a huge pain in the ass and i sort of bent the little plastic-ish dowel that goes between the seats that links them through the center support. lots of bad words and banging coming from the back seat of the 'beef car that day. i used a pry bar to move the seat out of the way a little bit to get the torx ratchet in there.
Instagram; @roastbeefmike
07-13-2017, 08:44 AM | #5 |
Rep 468
I just recently replaced my seats, and confirm that I did not have to remove the torz bolts. I can ALSO confirm that wiggling them out and getting the new ones back in does take some time and patience!
07-13-2017, 01:53 PM | #6 |
Rep 12,736
do you not have the split rear seats?
