06-16-2017, 07:32 PM | #1 |
Rep 57
S65 Spark Plug Issue
So I've spent the past hour trying to remove the drivers side spark plug that's in the confined space.... Can someone please share a method?
06-16-2017, 07:52 PM | #3 | |
Rep 57
I start by placing the 5/8 spark plug socket w/ a 3 inch extension through the hole and on the spark plug by itself. Then when i connect my ratchet to the extension, I seem to loose grip on the plug and I have no leverage to loosen it - hope that makes sense.. |
06-16-2017, 09:43 PM | #5 |
Rep 413
Not sure of your skill level/tools on hand, but if you run down to your local auto parts store you can probably pickup a cheap universal joint and extension that will allow you to get a better angle and more leverage on the spark plug removal socket. I use this combination plus what you are already using when removing the more difficult to reach spark plugs. This combination allows you to push down further onto the spark plug so that the spark plug socket seats properly.
GT172I6.00 |
06-17-2017, 09:29 PM | #7 | |
Rep 323
06-27-2017, 11:07 AM | #8 |
Rep 378
For the plugs closest to the firewall i doubt you will want that 3 inch extension added between the ratchet and universal joint, as the joint itself should add enough height out of the tube. The extra extension will just run you into obstructions.
06-27-2017, 04:17 PM | #9 |
Stop the hate, get a V8
3853
Rep 8,625
I would not use an impact driver on something as fragile as a spark plug in an aluminum head.
Past: 2011.5 M3 sedan ZCP |
TheMidnightNarwhal2677.50 |
06-27-2017, 07:14 PM | #10 |
Rep 117
07-02-2017, 07:05 PM | #11 | |
Rep 466
07-06-2017, 04:19 PM | #12 | |
Rep 57
That setup saved my life. Thanks man! |
