06-17-2017, 03:26 AM | #1 |
Rep 487
Dying battery, less hp?
Battery (7yrs old) finally starting to fail, replaced it today and now my car seems to be slightly more "fluid" in the mid to top range.
Placebo effect or does a failing battery really affect performance? |
06-17-2017, 01:35 PM | #2 |
Rep 3,623
Generally speaking when you are driving you are using alternator power, the battery just starts the car. That's way oversimplified but I'm pretty sure you're imagining things.
06-17-2017, 03:42 PM | #3 |
Bergspyder
1482
Rep 1,216
Does pulling battery reset adaptations?
I think it does. If so that is what you are feeling...
07-07-2017, 10:01 AM | #4 |
Rep 3,547
I think it also depends some on how the battery fails. My wife's shorted or something and would not take a charge at all. Too jumping on both ends - battery and under hood - to start. The dash was all lit up when it ran. I wouldn't be surprised if she was on the backup tune it uses when there are check engine messages (although it had none). If it goes to the backup tune it probably affects power.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
07-07-2017, 10:49 AM | #5 |
Rep 6,196
When the battery is in good condition, it only charges the battery when decelerating. Think of it as a light hybrid kind of mode. Below 80% charge, it will charge while normal driving. So car probably thought the battery was weak and charging it during accel as well.
So yes, it can affect performance. |
tracer bullet2502.00 |
07-07-2017, 12:13 PM | #6 |
Rep 1,850
I've heard of batteries causing some mysterious behavior but it's rare. And the alternator saps less than 2 kilowatts max from the engine, all things considered including inefficiency. Generally it would pull quite a bit less even when charging the battery. That's like 2.5 horsepower MAX, not nearly enough for you to notice unless you can hear people whisper from 10 miles away or detect earthquakes minutes in advance.
07-11-2017, 05:41 AM | #8 |
Level 1 BMW Tech
25
Rep 62
Pulling the battery does not reset adaptations.
If you didn't register the battery for replacement, nothing has changed. The vehicle will continue to charge your new battery like the old one. Which brings me to my last point, register the battery. I don't know of at home solutions, someone can chime in there. We had an incident where a technician twice replaced a battery and shipped it without registration. Both cars started coming back at 6 months to a year with weird electrical issues. They car will continue to not keep a full charge/ 80% charge on the battery. It will start charging the battery to 50-60% as time goes on. Doing this on an old battery is fine, doing this to a new battery will decrease its life. On top of having other issues.
Options: Sunroof delete, Sport Package, Xenon
Mods: M Performance Suspension, BMW Style 197 Wheels/ PSS Tires, M Sport Steering Wheel |
