06-22-2017, 02:31 PM | #1 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Recent track day results
2011 Z4 35is
MHD OTS Stage 2+ 93 Oct map Catless Downpipes 7" intercooler Turbo inlets and outlet Charge pipe with BOV Stock suspension Had 3 20min sessions at Gingerman raceway. This is a 2 mile track described as "The course layout simulates the full spectrum of driving situations: high speed straights and short sprints, long sweeping corners and tight apexes, heavy and light braking, and elevation change." The good news: The car ran great with a few exceptions mentioned in a moment. It was a sunny day with air temp 77-80 DegF. Oil Temp climbed to 260 and came back down quickly Burned no oil as far as I could tell from the iDrive display The stock brakes held up just fine and this course is very hard on brakes. I did not get a single limp mode, misfire, or codes of any kind What could be better: My rear tires chewed up my plastic rear wheel liner. I have the wheels pushed out but I didn't expect the rubbing to be so bad. Perhaps my liners are not installed correctly and sit too low? I am just a novice driver so I'm sure I had some terrible technique, but I can also see the desire to improve the suspension on this car. At turns 3,4,5 and 7,8,9 felt like the car was all over the place when switching directions. The not so good news: This has me puzzled and I am interested in any thoughts you may have here. Remember - No error codes of any kind and I did not try to log while in a 20min session Turn 10B goes into that long straight where I could hit 120mph if the road was clear. Long sweeping turn, elevation to a blind hill then that awesome straight. At around 100mph and accelerating, I would lose power in a surging sort of behavior. Things that seem plausible to me: - Throttle closure but due to what? - DCT slipping? Our DCT is rated a lot higher then where I am power wise right? -Fuel seems most likely to me. I know I was low on fuel so possible fuel starvation? But, If the fuel sloshes away from the pump and the engine doesn't fire correctly that would get me an error code right? |
06-23-2017, 08:06 AM | #2 |
Rep 906
Thanks. That removes the DCT as a reasonable possibility.
I am more convinced this was a fuel problem but, if so, why no codes of any kind? I suppose if the DME handled the condition exactly like it was supposed to then no need for a code? |
06-23-2017, 03:02 PM | #3 |
Rep 587
I recently went to a track day at California Speedway and also had no trouble. Oil temps got a bit higher in the roughly 95* ambient temps but also came back down very quickly, and I also had no braking issues with the EBC Yellowstuff pads on stock hardware. I did notice something interesting when I checked for a code that appeared the next day though. The code that set the light was for an O2 sensor so perhaps the extended and repeated time at full throttle (I hit 140 mph by the end of the front stretch) with the MHD stage 1 tune was enough to euthanize that sensor. The interesting thing I saw though was a shadow code that said something about reduced power (which I never noticed) due to front brake rotor overheating. Of course our cars don't have actual temperature probes there so maybe it calculates rotor temps based on ambient temps, speed, and deceleration. Maybe yours actually did reduce power because of perceived brake overheating?
06-23-2017, 10:30 PM | #4 |
Rep 906
Interesting about the brake temp warning. Something to try and read more about.
06-26-2017, 05:37 PM | #5 | |
Rep 887
On a side note, are you running stock air box + filter? I would recommend going with some sort of cone set-up, especially since you have inlets and outlets. The stock air box is a choking point. If you open the air box you can see all the air flow is limited to very small openings. I don't think you are able to take advantage of the inlets/ outlet with oem box. I went through this when I dyno'd my car after inlets. The gains were minimal due to stock airbox. After switching to AFE dual cone the car felt MUCH better. Anyways just some food for thought.
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
07-20-2017, 01:04 PM | #6 | |
Rep 412
Just ordered the KW V3, what settings are you running on street and track if you go on it? Did you see a real difference with the HR sway bars? Not loosing too much in confort? Thank you
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
