06-29-2017, 09:53 PM | #1 |
Rep 363
Pad Burned Onto Rotor after 1 Track Day
Hey Guys,
In the process of Obtaining PFC 08 to hopefully scrape this down. This was from a track day on OEM pads. What do you think? upload pics to internet |
06-29-2017, 11:15 PM | #3 |
Stop the hate, get a V8
3853
Rep 8,625
Consider using one of these on your power drill:
https://www.amazon.com/dp/B007INTE3Q...=2VKLVL1OJNHBA
Past: 2011.5 M3 sedan ZCP |
07-04-2017, 03:49 PM | #4 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Maybe next track day try to get a cool down lap after pushing the car. Also try and park on level ground and chock the tires as opposed to using brakes or parking brake. Applying a parking brake after laps may warp the inner hat. This is the result of you staying stationery with brakes applied to HOT ASS ROTORS!
07-05-2017, 04:03 PM | #5 |
1951
Rep 1,909
Drives: E92 M3
Not only are your rotors hot but the pads are hot as well. A long cool down lap or drive at moderate speeds (>25 MPH) to have a good amount of airflow is very important.
I recommend bringing a leaf blower to track days and alternating blowing air at the pads and rotors all around when you're parked. It'll help avoid heat building up between the pads. It's a low tech but very effective solution that's used even in F1. |
07-05-2017, 06:21 PM | #6 |
Rep 5,507
I've found the times I don't get a cool down lap at the track, I usually do a few laps around the paddock at regular paddock speeds will help before parking.
Auto Detailing Enthusiast!
07-06-2017, 07:29 AM | #7 | |
Rep 842
I'm sure I probably don't have to tell you this now, but don't ever run stock pads on the track. Regardless of what the manufacturer tells you, pads designed to quietly take you to the grocery store are not optimized for the searing heat of track use. When they overheat, they will essentially melt and stick to the discs as you have seen. |
