07-10-2017, 11:31 PM | #1 |
Rep 52
How to fix scratches on wheel?
I have some scratches on my wheel,they are not crub rush. I think it was scratches by washer who washed my car. Is there any way to fix it without painting job? Like waxing? Thanks for answering
Never let stupid guys to wash your car. |
07-10-2017, 11:45 PM | #2 |
Rep 2,995
is that wheel black?
you can try buffing the scratches with some rubbing or polishing compound. but if the scratches are through the paint, then not too much you can do. use a black sharpie marker to hide scratches... |
07-11-2017, 08:35 AM | #5 |
Registered Member
661
Rep 608
It is horrifying to see what tools "professionals" will use when cleaning your car. In my experience it is very rare to find somebody who will do the job properly, which involves a clean sponge or a clean towel and a little elbow grease. At the end of the day they just want to get your car in and out as fast as they can so they will use the tool that best facilitates that, in most cases it is a brush of some kind and many resort to using it like a hammer to get into the small nooks quickly (and lazily).
07-11-2017, 03:59 PM | #7 |
Rep 452
If you can put ur nail in it then polishing it wont work. I would say just use some black marker or nail polish and get it done with it. Black is quite forgiving.
07-11-2017, 06:37 PM | #8 | |
Rep 52
Yep ,I am gonna do polishing first . See if it works. I think you are right ,I can put nail in it . Probably won't work. But thank you any way. Remind all members, you should never let stupid person to wash your car. You will spend more to fix damages. |
07-11-2017, 06:59 PM | #9 |
Rep 625
Yes, this can be corrected using a dual action polisher like Porter Cable, Harbor Freight, or Griot's Garage dual action polisher.
If you'd like to DIY there's starter kits online via Autogeek Online. Or find a local detailer and get it done. If you can catch the scratch with your nail, it has to be filled in with paint. |
07-11-2017, 07:32 PM | #10 |
Rep 2,995
who is this 'stupid person'?
07-11-2017, 07:57 PM | #11 |
Rep 52
07-11-2017, 08:55 PM | #12 | |
Rep 2,995
did you go back and complain? make them repair it? |
07-11-2017, 11:48 PM | #14 | |
Rep 2,995
they probably been using a worn out wheel brush with exposed metal. its sad to think how many other cars probably got scratched. |
07-12-2017, 01:53 AM | #15 | |
Rep 52
07-12-2017, 07:30 AM | #16 |
Registered Member
661
Rep 608
Doesn't matter if a brush is brand new, it should never be used to clean the exterior of a car. Unless of course you don't care about the car, which is why so many car washes use them, because they don't care about your car they only care about getting your money. They know that most people are too oblivious to even notice.
JVX6M166.00 |
07-12-2017, 03:00 PM | #17 |
Rep 865
This is precisely why I am the only one who washes my cars. Most painted wheels have a clear coat on them. If you have experience or want to take the chance, you may be able to remove the scratch through polishing, or light wet sanding. Either has the chance to go through the clear coat, but you can apply another coat of clear over the entire wheel with a trim spray gun.
Worst case at least here in the States, a wheel can be refinished for about $150 and with a good refinish, you'll never know.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
07-12-2017, 03:08 PM | #18 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
In the past we have buffed it a scratch out and it worked. If its deep you may need to repaint that area. Find out if there's a wheel guy in your area you can take it too. Would start around $50 on up... Good Luck
