07-11-2017, 10:38 PM | #1 |
Rep 619
I just finished installing a dinan front sway bar. The issue, or maybe not, is that once I turn the wheel, either left or right, that side of the car lifts. Is this normal? According to my friend it is. Any advice?
07-11-2017, 11:48 PM | #2 |
just another M3
514
Rep 1,152
A slight lift is normal. It did that before but you didn't notice.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
07-14-2017, 02:36 AM | #3 | |
Rep 619
09-16-2017, 08:10 PM | #6 |
Rep 619
09-17-2017, 08:45 PM | #7 |
Rep 1,239
i think i got screwed. i cant figure out how to thread on the endlinks. i got 3 counterclockwise joints and one clockwise thread. i ended up just using my stock endlinks. is there any issues doing this?
09-17-2017, 08:48 PM | #8 | ||
Rep 619
You should be ok for a bit but I'd replace them asap. The dinan ones are much stronger and with a firmer sway bar you'll need the stronger links. Just send it back to dinan |
09-17-2017, 09:25 PM | #10 |
Rep 619
09-17-2017, 09:43 PM | #11 |
Rep 12,736
it is when you install the bar with tension already on it when the car is at rest. i don't think i've ever heard of a weekend guy doing it on purpose... it usually results in a cracked bar. its a pro-racer kinda thing that i'm not familiar with.
Instagram; @roastbeefmike
09-18-2017, 11:53 AM | #12 |
Rep 1,239
is this done by using the 3 different holes?
A job is nothing but work.
09-19-2017, 06:17 PM | #13 |
Rep 267
The 3 holes are for different swaybar stiffness settings. The (edited, thanks @m43s7ro) stiffest setting is closest to the center of the bar, and the softest setting is the furthest from the center of the bar.
You do NOT want a preloaded swaybar on a street car. Swaybar preloading requires adjustable endlinks, and is really only useful for NASCAR type circle track racing, where you'll only be turning in one direction. Last edited by SpartaEvolution; 09-21-2017 at 11:15 AM.. Reason: I done goofed |
09-20-2017, 12:35 AM | #14 |
Rep 12,736
they are for adjusting stiffness. adding stiffness is different than preload. they are not the same. you can add stiffness without adding preload.
09-21-2017, 08:01 AM | #15 | |
Rep 1,055
Correction, furthest holes from bar are softest setting, closer to bar is stiffer as it creates less leverage and thus is harder to twist the bar.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
SpartaEvolution178.00 |
09-21-2017, 11:12 AM | #16 |
Rep 267
10-04-2017, 12:45 AM | #17 |
Rep 1,239
