07-26-2017, 07:44 PM | #1 |
///M SubDriver
1844
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
Request Help Diagnosing Extra "Air Sound" with Burbles & Pops
So yesterday I noticed a new sound coming from under/behind the car in addition to the normal burble and pops/overrun. It sounds like a quick, split second burst of air, almost like a very quick blow-off, at the beginning of the overrun and then right at the completion of the overrun sequence. It almost sounds like a slight, pressurized exhaust leak. So the sequence is: lift off gas -> "air sound" -> burble and pops/overrun -> "air sound"
It only makes this sound when the car is in Sport or Sport+, when overrun is active. In Efficient mode, when overrrun is not active, there is no air sound so I don't think it is some component that is flopping around under the car. My car was at the dealer last week getting some work done: oil pan replacement and trans oil drain/refill. My first thought is that maybe a vacuum fitting may be loose or something, which might explain the very brief air noise I am hearing, or possibly an exhaust leak that only occurs with the overrun. But other than that, I don't have s clue as I am not familiar with what may have been taken apart when the other work was being done. I am pretty sure I am not "hearing things" even though I just got my car back from the dealer. It can be easy to get a bit paranoid and your mind plays tricks on you. But I have always been a fan of the burbles and pops, sometimes listening to it with the windows down and radio off (I know, a bit weird - but I am sure I am not alone ). So when I first heard this extra air sound, I knew something didn't sound right. I don't have any CELs or warning lights and the car otherwise seems to be running fine. So anybody with a '16+ stock ZCP care to listen to their own overrun to help verify my mind is not playing tricks on me? Any ideas what this could be? I plan to take it back to the dealer but would like to be armed with some troubleshooting ideas if possible. While I can hear the air noise in question while driving with the windows down and radio off (especially if close to barriers on the side of a road or in a tunnel), I can also hear it very clearly when blipping the throttle in the garage - as the noise bouncing off the walls makes it real easy to hear. The engine just needs to be a bit warm since the burble and pops don't become active until ~2-3 min after the engine is started, especially if it is a cold start. Thanks!
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 07-27-2017 at 12:09 PM.. |
07-27-2017, 12:27 PM | #2 |
Rep 981
My intakes exaggerate turbo noises. Lately I've been running around in Sport+ mode and have noticed this too. It's the blow off/ diverter valve, I guess the extra boost or other settings makes it more pronounced.
07-27-2017, 02:11 PM | #3 | |
///M SubDriver
1844
Rep 2,787
However, I never remember hearing any type of blow-off valve noises from this car as my understanding is that the blow-off is recirculated back into the intake and not to atmosphere (I could be wrong here though ). As I mentioned above, I can make it do this sound even blipping the throttle at idle - where boost buildup should be very low. But of course the most convincing thing to me is that I am VERY confident it was not there before. I just wish I had a local, stock ZCP owner close to me to listen to since I know exactly what to listen for to verify with certainty that something is amiss (or not).
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
07-27-2017, 05:19 PM | #5 |
///M SubDriver
1844
Rep 2,787
Yup, it is almost like it is a switch noise, turning the burbles on, then off. Except the switch noise sounds like a very quick puff of air, like when you disconnect an air hose from filling your tires with air.....
07-28-2017, 07:28 PM | #6 |
Rep 2,809
It's the EWGs opening. It's actually a rattle.
The EWGs have more function than just controlling boost. They play a large roll in Sound Tuning as well. In aggressive burble overrun mode, the DME opens the EWGs. Last edited by CaryTheLabelGuy; 07-28-2017 at 07:34 PM.. |
07-28-2017, 07:44 PM | #7 | |
///M SubDriver
1844
Rep 2,787
What would be the next step to possibly address the issue? |
07-28-2017, 09:06 PM | #8 | |
Rep 2,809
Wastegate rattle gets worse with time. IMHO, they are always audible to me. Every S55 I've heard had it, some are just worse than others. If it's supper annoying, BMW would need to replace the turbos to stop it and it would probably eventually come back. |
07-29-2017, 06:18 AM | #9 | |
///M SubDriver
1844
Rep 2,787
So if I do take this back to a dealer to investigate this air noise, what would be your recommended tactic? Is there any more knowledge I can use as ammo to help address this issue? I always like to come in armed with specific info so that the dealer knows they are not dealing with an amateur when it comes to troubleshooting problems, and to help prevent a complete "Easter egg" hunt as they try to diagnose the problem. What always sets me off with any dealer is when they give me the automatic response of "that is normal" or something similar without really considering that something may be wrong that requires at least some basic troubleshooting to help diagnose the issue. This is even after I provide them a detailed description of the problem.
07-29-2017, 07:12 AM | #10 | |
Rep 2,809
The electric stepper motors that make up the EWG units can have a weird sound when they move and the wastegate actuator arms do have a rattle (what I was speaking of earlier). What was your recent repair? Did it involve downpipes and/or turbos? |
07-29-2017, 11:48 AM | #11 | |
///M SubDriver
1844
Rep 2,787
07-29-2017, 12:55 PM | #12 | |
Rep 2,809
07-29-2017, 02:16 PM | #13 |
///M SubDriver
1844
Rep 2,787
07-29-2017, 05:15 PM | #14 |
Rep 2,809
07-30-2017, 05:10 PM | #15 |
///M SubDriver
1844
Rep 2,787
Ok, I took two videos a little over 20 seconds each, blipping the throttle several times. The first video is from the top of the car, on the passenger side of the engine compartment. The second video is from the bottom (side) of the car, also on the passenger side. The offending noise in question can be heard in each video, although it is easier to hear in the second video. It is also harder to hear the noise at the beginning of the overrun sequence, but you can definitely hear it at the end of each overrun sequence. Once you know what to listen for, it will be easier to hear it at the beginning of each overrun sequence.
https://youtu.be/nxD_OTGb_64 https://youtu.be/_bQ9Q6Pr1XA |
07-30-2017, 06:10 PM | #16 | |
Rep 2,809
I wouldn't worry about it, it's very normal as even my ZCP does this and did this since brand new. |
07-30-2017, 10:32 PM | #17 | |
///M SubDriver
1844
Rep 2,787
At least I have some knowledge of what I am dealing with now - thanks.
