08-03-2017, 04:17 AM | #1 |
Rep 150
380BBK on 18" wheels. Wont it be hot?
Hello all.
My common sense says that a 380mm BBK on 18" wheels will make the cooling significantly worse? Since it sits so close to the wheels and air cannot get to the brake vents as much? What are your thoughts? Look at how close that brake's vent is to the wheels. Wont this limit or block air into the vents? |
08-03-2017, 08:49 AM | #2 |
Rep 5,482
08-03-2017, 10:23 AM | #3 |
Stop the hate, get a V8
3853
Rep 8,625
I've never heard of it being a problem. Remember that a ton of air is fed to the back side of the rotor anyway.
Past: 2011.5 M3 sedan ZCP |
08-07-2017, 03:54 PM | #4 |
Rep 92
If the discs are installed correctly, the vents pull fresh air from the hub area and throw it out the edge. As long as there's enough clearance for the vented air to escape out the disc edge, it will work fine.
I have 380's on 18's and there's plenty of clearance. |
08-10-2017, 06:52 PM | #7 |
just another M3
514
Rep 1,152
The air enters the rotor from the center and exits at the edge of the rotor. I have that setup and cooling is not affected.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
