08-08-2017, 10:42 AM | #2 |
Rep 10,509
I can't read German but looking at the section speeds and lap times it looked like the CS was able to maintain a bit higher speeds mid corner (due to cup tires?) but gtr overpowers it in the straights.
Is that correct? |
996ttelise385.00 |
08-08-2017, 08:26 PM | #4 |
Rep 1,857
My German is as good as yours. But yeah, GTR is a lot heavier and slower around the corner. However, in the hands of your everyday amateur like most of us, we can probably drive the GTR quicker around a corner due to the confidence we get from the AWD.
08-08-2017, 10:34 PM | #5 |
Rep 181
According to their weights the GTR is only 160lbs heavier, R compounds are the difference maker.
08-09-2017, 12:57 AM | #6 | |
Rep 1,857
08-09-2017, 08:56 AM | #7 |
Rep 621
The GTR was still much faster despite not being on R compounds like the CS. Equal that out and you're going to see the gap between them grow to ~3 seconds in favor of the GTR.
08-09-2017, 09:03 AM | #8 |
Rep 181
For sure I dont think anyones arguing which is the faster car, just that the tires on the CS help it look closer than it really is.
08-09-2017, 09:35 AM | #9 |
Rep 20,742
Drives: 2021 911 turbo
There is even a caption that says the GT-R is over 170kg heavier. According to the data oanel, it is 173kg heavier, which means over 381lb more...
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-09-2017 at 09:48 AM.. |
08-09-2017, 09:36 AM | #10 | |
Rep 20,742
That being said, with a 110hp advantage a 4WD, it's no surprise the GT-R is faster, it has always been a track monster. The M4 always had a fair price advantage over the GT-R. But now, with the hefty premium they are charging for the CS, the value proposition isn't as compelling.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-09-2017 at 10:45 AM.. |
08-09-2017, 11:05 AM | #11 | |
Rep 621
Also, that test was a manual z06 and really don't like comparisons unless it's Apple to apples. Also to note, that was the Nismo GTR too. I do totally are though... the pricing on the M4 GTS and CS is simply getting outrageous given it has a hard time keeping pace with cars in the same price range and even more so cars that are cheaper. They're pricing themselves out of competition and trying to make people feel better thinking they're getting something special when it's more of the same old with a couple tweaks. Last edited by Motorsportenterprise; 08-09-2017 at 11:11 AM.. |
08-09-2017, 11:13 AM | #12 | |
Rep 20,742
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-09-2017, 03:07 PM | #13 | |
Rep 139
http://www.motortrend.com/cars/chevr...-track-retest/ |
08-10-2017, 06:04 AM | #14 | |
Rep 20,742
Although, it seems the Z06 improvements come from more than just alignment with Chevy also re-calibrating the dampers. Interestingly, the 8AT Z06 was 0.76 seconds slower than the manual (equal to the GT-R). But, in the end, my point still holds, the tires on the GT-R grip nearly as much as PSC2.
08-10-2017, 08:34 AM | #15 | |
Rep 1,025
- The stock run flats are extremely heavy. They weigh almost 10lbs more per tire than a comparable non runflat. That's close to 40 lbs of unsprung weight at the worst possible location. - They are relatively narrow. Even the Nismo only uses 255 fronts and 285 rears, same as the premium model. For a heavy front-engined car, that's pretty narrow. The Z06 uses 285s on the same size front wheels, and one of the things GTR owners frequently do is switch to wider tires. Using a 285/315 set of R888s (which fit on stock wheels) makes a huge difference and that's what they run on some of the One Lap cars that dominate the field. - The compound is also a step behind the cups and R comps, but it's not the only problem.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
08-19-2017, 04:38 AM | #16 |
Rep 762
I recall the time on M4 GTS here was 1.36.8min vs 991 GT3 RS(1.35.0)(same magazine testning)
It seems there are more or less same diff vs this Nissan and BMW CS then. Have yet to read this test. Might be different drivers Iguess, have not read this test but I would guess a M4 CS you should sit closer to GTS than this. Also when M4 GTS test here with this magazine It was god cool conditions out. Recall 10 degrees outside temp. Could M4 CS test been on a very hot day? |
08-19-2017, 06:19 AM | #17 | |
Rep 20,742
