09-07-2017, 09:25 PM | #1 |
Rep 288
Drives: '22 X4 M40i / '24 X5 M60i
Oil leak at 9,000 miles
Just dropped off the car at the dealer.
July 2015 production. 15,000 km on the odometer. Daily driver, 10 miles long commute. During the oil change in August the service department reported oil pan leak. I did not notice any oil dropping on the garage door floor. The iDrive still shows oil at the max level, same as before the annual oil change. The repair is covered by the warranty, but I am not thrilled by the fact that the oil pan will need to be replaced (assuming based on what the service associate said). Could not find anyone mentioning dealing with the oil leak at this F80/F82 forum. To have the car leaking oil after 2 years is definitely bummer . I wonder how well the repair will be done and if there will be other connecting issues coming... |
09-08-2017, 07:48 AM | #2 |
Live for today tomorrow never comes
1990
Rep 9,499
Never heard of this one before, could be a number of things, loose bolt, poor gasket fit, cracked sump, what puzzles me is WHY they left it.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
09-08-2017, 09:55 AM | #3 |
Rep 288
I assume they left it without any fix in August because the annual oil change was done as an express service (within 2 hrs max), and they did not have shop capacity to investigate the exact cause on the same day.
I was asked to bring the car back after my return from 3-week long vacation in Europe. The car was parked in my garage for the trip duration. I double-checked with the service that it is not critical to bring the car to the shop before the trip, they said that it is ok since the car will not be driven. |
09-09-2017, 06:00 PM | #5 |
Rep 288
Oil leak was fixed yesterday by replacing just the pan gasket. So the original oil pan was not replaced.
05-26-2018, 10:45 PM | #6 | |
Rep 255
This shows on my service invoice: (Diagnostic - Oil Leak (Visual): Tech. notes that there is a dripping Oil leak. Customer will need to return/drop off for Diag./repairs. Shop Foreman consulted. (W)) He said it wasn't serious and I could still drive, but to schedule a diagnostic as soon as possible. I'm dropping it off on Tuesday. More to come. |
05-27-2018, 02:35 PM | #7 |
Rep 1,391
And BMW has yet figured it out, designing a better gasket or metal lip joint on high heat low emission engines. All BMW N54 and N55 engines leak oil at many places, I have a feeling this S55 is no different.
05-28-2018, 10:31 AM | #8 | |
Rep 761
And to make it worse, the lowest part of the oil pan casting is the three studs used to mount the oil level sensor - these stick out vertically downwards. All this is covered by a flimsy metal sheet that gives the appearance of protection. If your car is lowered and you take a speed bump a little carelessly there is a very real chance that these studs will impact the ground and crack the casting (and probably destroy the $500 oil sensor in the process). See photos below of my 'small oil pan leak'. You can see the crack in the casting in the second photo :-( Sounds like you were very lucky in that a leaking gasket can be replaced without having to remove the sump pan completely! Last edited by pbar; 05-28-2018 at 10:43 AM.. |
05-29-2018, 01:58 PM | #9 |
Rep 1,391
on all BMW engines I know of, dropping oil pan to replace it's gasket means subframe needs to be unbolted, the engine needs to be secured to suspension tower or on reliable engine crane. Not easy like replacing transmission oil pan
05-30-2018, 10:41 AM | #10 | ||||
Rep 255
Final Update: I finally had my M3 repaired for the oil leak. It took two weeks to source parts listed below from Germany. Side note, my dash cam (Thinkware F800 Pro with the Cellink B battery backup installed) was able to work for 2 weeks without starting the car. It picked up motion and recorded video from when I dropped it off May 29th until I picked it up on June 20th. Last edited by Rockshaker; 06-21-2018 at 11:50 PM.. |
shay2nak1070.00 |
06-22-2018, 04:28 PM | #11 | ||||||||||
Rep 255
UPDATE: I received my check from my BMW dealer today for $500. |
shay2nak1070.00 |
06-23-2018, 12:23 AM | #12 |
Assistant TO the Regional Manager
617
Rep 728
Rockshaker, thanks for the detailed update. Glad it hear it is taken care of. The dealer seems quite on top of things!
BTW what's the reference to PDR? Or was it a clear bra re-application? |
06-23-2018, 05:08 PM | #13 |
Rep 255
I had a scratch repaired by Dent Wizard through BMW and they were suppose to reapply Ceramic Pro at the time scratched was fixed 2 months ago. They finally got around to doing it.
10-19-2018, 04:15 PM | #14 |
Rep 288
15 months update
So here is an update on the initial oil leak repair.
Although no drops were found on the garage floor before the first repair (oil pan gasket replacement), about 10 months after this repair, the oil drops started to appear. The weather in May was unusually warm in our area and the oil dropped (1 or 2 drops) always after I was driving the car a bid harder. Maybe three occurrences over 5 weeks. I scheduled the repair and dealer diagnosed the oil level sensor to cause the leak. It was replaced and the oil service was done at the same time. About 10 days later, single drop appeared on the garage floor again. I reported to the dealer and left for 3 weeks in Europe. Upon return, I checked the floor and it was clean. I took the car for a spin (about 30 miles running errands) and next morning I found two drops on the floor. I schedule the service for 2 weeks later. BMW dealer kept the car for 9 days. They were also replacing both taillights due to heat cracking. The scope of work is explained here: 2 weeks since the repair, I see no signs of new leak on the garage floor. I am not thrilled that they did not really find what happened , since they said the gasket replacement was done properly in July 2017. I suspect this is not over yet... |
