10-10-2017, 07:33 PM | #1 |
Rep 75
DCT and turbo lag - noticeable?
Currently I have a 2017 VW Golf R with the DSG transmission. It's very quick shifting and smooth, but probably my biggest complaint is in the turbo lag that it seemingly creates. Now, this can be mostly avoided by driving in "sport" mode as the shift points change and become more aggressive. But this is not ideal for daily driving, in and out of traffic. Essentially, in "normal" mode, you have to smash the gas pretty good triggering a downshift to get up in the RPM's for the turbo to spool up.
One difference between the Golf R and the M3 is obviously single vs. twin turbo. I'm wondering if this twin turbo setup helps with the turbo lag? With the DCT, do you find the same issue, or is it rare to non-existent? Thanks for any feedback! |
10-10-2017, 08:40 PM | #3 |
Rep 27
I think the VW/Audi DSG's throttle-by-wire system itself is laggy; I felt the same way as you about a 2017 A4 I drove. No such issue on my 2018 M3, thankfully. It doesn't quite feel as linear as a N/A engine of course, but the throttle is very responsive and sensitive in Sport and Sport Plus modes. Efficient mode has some noticeable lag but even there it's much less than in the A4 I drove.
10-10-2017, 08:47 PM | #4 |
Rep 6,870
I believe in the golf r switching between normal, sport, etc changes both throttle sensitivity and transmission aggressiveness. In the M3, these functions are controlled separately so you could be in D1 which is the least aggressive transmission shift setting and sport+ which is the most aggressive throttle setting.
10-10-2017, 08:51 PM | #5 |
Rep 2,419
Let me five you an example. If the car was in comfort mode and you floor it, nothing happens for like 2-3 seconds, and then it starts moving fast. If it was in Sports or Sports+, that lag is gone.
The beauty of the DCT is upshift/downshifts are super fast and when you're in traffic just put it in auto mode and be done with it. The best of both worlds.
2012 BMW M3 E93 (Fire Orange)
Akrapovic Evolution Titanium Exhaust Arkym Style Front Lip/CF Diffuser/CF Side Skirt Extensions LUX H8 189 Angel Eyes 2023 Nissan Z Performance (Ikazuchi Yellow) |
10-10-2017, 09:41 PM | #6 |
Rep 3,385
Hey, I'll let you take peek at it once I take delivery.
I drive my R in manual mode, so I don't really get any of the lag... However, the TCU tune for these things is supposed to help a lot. I will say that the M-DCT is completely different.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
10-10-2017, 10:37 PM | #7 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Once you drive in sport or sport plus it is hard to go back to efficient mode except for the most subdued driving / commutes.
Killed by Death12935.00 |
10-11-2017, 01:24 AM | #8 |
Rep 109
10-11-2017, 05:40 AM | #9 |
Rep 20,742
Drives: 2021 911 turbo
Drive it in manual mode. This way the downshifts are commanded by the paddles instead of the accelerator. This allows you to select the right gear before you accelerate just like you would with a manual transmission.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
Vectors2final1466.00 |
10-11-2017, 06:43 AM | #10 |
Moderator
7525
Rep 19,368
This. OP, put your Golf R in manual mode, and see if that doesn’t fix your “turbo lag” problem.
10-11-2017, 06:58 AM | #11 | |
Rep 1,360
10-11-2017, 08:18 AM | #12 | |
Rep 3,385
The difference(kick-down) between the DSG and the DCT is that the gears drop when you hit the kick-down button in the R. The R does take a second to build boost from a stop unless you use LC. The IS38 is a pretty decent sized turbo that only responds sooner with a tune.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M Last edited by Vectors2final; 10-11-2017 at 10:26 AM.. Reason: derpity derp |
10-11-2017, 09:59 AM | #13 |
Rep 1,014
I'm still breaking car in, so no WOT yet.
With a good push of the pedal, I don't think there is significant lag, especially compared to my '14 435 (even w the JB+ chip). I've found the D2 seems to be better than D1 for local driving. Haven't tried D3 yet. I think the DCT is as smooth or smoother than Steptronic in Sport Mode. That said, everyone modding regular 3/4 series cars should just go for am M3/4. Stay tuned for what I think after the winter. Despite that it has been said that BMW recommends Comfort mode steering, I like Sport, but haven't tried S+ yet. Haven't tried S+ on the engine or suspension yet either. Not sure I've done Sport on the suspension come to think of it. Haven't tried MDM either.
///M4 'vert
10-11-2017, 10:20 AM | #14 |
Barge driver
8691
Rep 12,437
Manual mode gets the best out of DCT, using auto always gives rise to the ghosts in the machine whatever the car or gearbox.
730d/Z4C
10-11-2017, 11:03 AM | #15 |
Rep 738
Turbo lag is noticeable even in Sport+ mode. The lag is more noticeable when I suddenly give it full throttle. It FEELS like 0.5 - 1 sec lag.
Edit: I have a DCT.
10-11-2017, 11:34 AM | #17 | |
Rep 20,742
I gather they recommend the Sport setting since that is what they have set as the default
10-11-2017, 11:35 AM | #18 | |
Rep 20,742
Because at 5000+ RPM, there is barely any lag.
10-11-2017, 02:40 PM | #19 |
Rep 11,763
Drives: 2018 M4 Comp Indv
Do you mean lag or full boost because the power isn't linear? There's no lag, but there is non-linear power delivery.
10-11-2017, 02:44 PM | #20 | |
Rep 738
Edit: It’s what I’m experiencing and the car has no problem.
10-11-2017, 09:56 PM | #21 |
The G8X is a disaster. 🤮
931
Rep 988
The M3/M4 was specifically designed with two smaller turbos, rather than one large one, because small turbos spool more quickly. There is (or was) a demonstration of this at the BMW Welt...it's basically a large wheel you can spin by hand and a smaller one that is much easier to spin due to the reduced rotating mass.
In the real world, I have boost on before 2000 RPM, so I don't have any lag in D1/S2. |
10-11-2017, 10:37 PM | #22 | |||||||
Rep 75
Thanks everyone for the feedback!
I've just never been that big of a fan of driving the DSG in manual mode. I completely get the rationale and the performance (lack of lag) is diminished while doing this. I do like sport mode, but sometimes feel that the car holds the gear longer than I would prefer, LOL. And yes, I've heard that the TCU tune helps as well, but don't plan on putting more $ into the car if I'm going to part with it in lieu of an M3 sometime in the next year. Quote:
